Trevor68 70 Posted March 25, 2023 Posted March 25, 2023 (edited) Easy to test, re-enable the one you turned off, watch the ram suckage return. The files not being processed correctly will be in that library Edited March 25, 2023 by Trevor68
Happy2Play 9814 Posted March 25, 2023 Posted March 25, 2023 (edited) But it has to come back to amount if images as I have several Home Videos Libraries with Photos enabled. Or specific image types? Edited March 25, 2023 by Happy2Play
Trevor68 70 Posted March 26, 2023 Posted March 26, 2023 You don't have the problem though, it is not amount, it is certain files. Mine happily processes right up until 91% then it hits the same files that it doesn't like and immediately Hoovers up all available ram, then eventually crashes. If @Luke has fixed this for 4.8 then he can probably tell you exactly what is causing it.
Luke 42289 Posted March 26, 2023 Posted March 26, 2023 There is an issue in 4.7 with certain photos causing the scan to hang. This has been corrected in the upcoming 4.8 server release.
lightsout 156 Posted March 27, 2023 Posted March 27, 2023 On 3/25/2023 at 6:39 PM, Trevor68 said: You don't have the problem though, it is not amount, it is certain files. Mine happily processes right up until 91% then it hits the same files that it doesn't like and immediately Hoovers up all available ram, then eventually crashes. If @Luke has fixed this for 4.8 then he can probably tell you exactly what is causing it. My scan was completing, and not taking all that long. But even after completing the ram would just keep going.
Trevor68 70 Posted March 28, 2023 Posted March 28, 2023 I still have access to the old server files, is there something I can copy over to get around this? I have already copied the cache files, and also metadata/library, to no avail.
Luke 42289 Posted March 29, 2023 Posted March 29, 2023 On 3/27/2023 at 8:01 PM, Trevor68 said: I still have access to the old server files, is there something I can copy over to get around this? I have already copied the cache files, and also metadata/library, to no avail. You mean as a workaround instead of unchecking Enable Photos?
Luke 42289 Posted March 29, 2023 Posted March 29, 2023 15 minutes ago, Trevor68 said: Absolutely, is that possible? Unfortunately I don't think it's going to work out. One other idea I have, assuming you want to stay on 4.7, is remove the schedule of the library scan, and then when you add new content to other libraries besides the photos one, you can just run manual scans on them. And then once 4.8 is released, add the library scan schedule back to it's default of every 12 hours.
Trevor68 70 Posted March 29, 2023 Posted March 29, 2023 Kind of also defeats the purpose, guess I just decided to migrate at the wrong time. Will wait on 4.8 for the fix. I'm guessing that might be a bit yet?
Luke 42289 Posted March 29, 2023 Posted March 29, 2023 3 minutes ago, Trevor68 said: Kind of also defeats the purpose, guess I just decided to migrate at the wrong time. Will wait on 4.8 for the fix. I'm guessing that might be a bit yet? Hopefully not. We recognize this is a big issue with certain photos, so hopefully sooner rather than later.
Luke 42289 Posted June 1, 2023 Posted June 1, 2023 10 hours ago, Trevor68 said: So didn't make the cut for 4.7.13 then I guess? The photos change will be in the upcoming 4.8 release. Thanks.
Flieger42 1 Posted September 27, 2023 Posted September 27, 2023 So my server runs on stable version 4.7.14.0. This issue is still in the stable version. When will 4.18 be released as stable? I dont want to update on a beta server right now.
Luke 42289 Posted September 28, 2023 Posted September 28, 2023 On 9/27/2023 at 5:20 PM, Flieger42 said: So my server runs on stable version 4.7.14.0. This issue is still in the stable version. When will 4.18 be released as stable? I dont want to update on a beta server right now. Soon. we're working hard on it.
