samzzz 0 Posted March 22, 2023 Posted March 22, 2023 Hi May I ask what is the problem, it cannot be started after restarting emby-server.service - Emby Server is a personal media server with apps on just about every device Loaded: loaded (/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: failed (Result: signal) since Wed 2023-03-22 11:48:02 UTC; 6s ago Process: 318 ExecStart=/opt/emby-server/bin/emby-server (code=killed, signal=ABRT) Main PID: 318 (code=killed, signal=ABRT) CPU: 91ms Mar 22 11:48:02 emby systemd[1]: Started Emby Server is a personal media server with apps on just about every device. Mar 22 11:48:02 emby emby-server[318]: Unhandled exception. System.BadImageFormatException: Could not load file or ass> Mar 22 11:48:02 emby emby-server[318]: File name: 'Emby.Server.Implementations, Version=4.7.11.0, Culture=neutral, Pub> Mar 22 11:48:02 emby systemd[1]: emby-server.service: Main process exited, code=killed, status=6/ABRT Mar 22 11:48:02 emby systemd[1]: emby-server.service: Failed with result 'signal'.
samzzz 0 Posted March 23, 2023 Author Posted March 23, 2023 Establish directly through DPKG -i Emby-Server-Deb_4.7.11.0_amd64.deb directly installation
samzzz 0 Posted March 23, 2023 Author Posted March 23, 2023 root@emby:~# systemctl restart emby-server root@emby:~# systemctl status emby-server * emby-server.service - Emby Server is a personal media server with apps on just about every device Loaded: loaded (/usr/lib/systemd/system/emby-server.service; enabled; vendor preset: enabled) Active: inactive (dead) since Thu 2023-03-23 03:52:42 UTC; 297ms ago Process: 4948 ExecStart=/opt/emby-server/bin/emby-server (code=exited, status=0/SUCCESS) Main PID: 4948 (code=exited, status=0/SUCCESS) CPU: 1.128s Mar 23 03:52:42 emby emby-server[4948]: at Emby.Server.Implementations.ApplicationHost.GetComposablePartAssServer.Implementations.ApplicationHost.GetComposablePartAssemblies() Mar 23 03:52:42 emby emby-server[4948]: at Emby.Server.Implementations.ApplicationHost.DiscoverTypes() Mar 23 03:52:42 emby emby-server[4948]: at Emby.Server.Implementations.ApplicationHost.Init() Mar 23 03:52:42 emby emby-server[4948]: at EmbyServer.HostedService.StartAsync(CancellationToken cancellatierver.HostedService.StartAsync(CancellationToken cancellationToken) Mar 23 03:52:42 emby emby-server[4948]: Source: Emby.Server.Implementations Mar 23 03:52:42 emby emby-server[4948]: TargetSite: System.Collections.Generic.List`1[System.Tuple`2[System.ReSystem.Collections.Generic.List`1[System.Tuple`2[System.Reflection.Assembly,System.String]]GetComposablePartAssembli flection.Assembly,System.String]] GetComposablePartAssemblies() Mar 23 03:52:42 emby emby-server[4948]: Mar 23 03:52:42 emby emby-server[4948]: Info Main: Shutdown complete Mar 23 03:52:42 emby systemd[1]: emby-server.service: Succeeded. Mar 23 03:52:42 emby systemd[1]: emby-server.service: Consumed 1.128s CPU time. Try to reinstall the above baioc
Luke 42245 Posted March 23, 2023 Posted March 23, 2023 I'm really not sure what the issue is. Have you tried installing on the host OS directly?
samzzz 0 Posted March 23, 2023 Author Posted March 23, 2023 I just installed the above error on the host operating system
Luke 42245 Posted March 24, 2023 Posted March 24, 2023 On 3/23/2023 at 12:40 AM, samzzz said: reproduce this error What exactly happened on the host system? What is the host system? How did you install onto the host system?
