0v3rl0rd 5 Posted March 20, 2023 Posted March 20, 2023 So, I have a problem with multi-part movie(s). It's two movies: Superman (1948) - imdb link Atom Man vs. Superman (1950) - imdb link The movies are theatrical serials split in many parts, like this: superman_1948_pt01_theatrical_serial_superman_comes_to_earth.avi superman_1948_pt02_theatrical_serial_dept0hs_of_earth.avi superman_1948_pt03_theatrical_serial_the_reducer_ray.avi superman_1948_pt04_theatrical_serial_man_of_steel.avi superman_1948_pt05_theatrical_serial_a_job_for_superman.avi superman_1948_pt06_theatrical_serial_superman_in_danger.avi superman_1948_pt07_theatrical_serial_into_the_electric_furnace.avi superman_1948_pt08_theatrical_serial_superman_to_the_rescue.avi superman_1948_pt09_theatrical_serial_irresistible_force.avi superman_1948_pt10_theatrical_serial_between_two_fires.avi superman_1948_pt11_theatrical_serial_superman_s_delima.avi superman_1948_pt12_theatrical_serial_blast_in_the_depths.avi superman_1948_pt13_theatrical_serial_hurled_to_destruction.avi superman_1948_pt14_theatrical_serial_superman_at_bay.avi superman_1948_pt15_theatrical_serial_the_payoff.avi atom_man_vs_superman_1950_pt01_serial_superman_flies_again.avi atom_man_vs_superman_1950_pt02_serial_atom_man_appears.avi atom_man_vs_superman_1950_pt03_serial_ablaze_in_the_sky.avi atom_man_vs_superman_1950_pt04_serial_superman_meets_atom_man.avi atom_man_vs_superman_1950_pt05_serial_atom_man_tricks_superman.avi atom_man_vs_superman_1950_pt06_serial_atom_man_s_challenge.avi atom_man_vs_superman_1950_pt07_serial_at_the_mercy_of_atom_man.avi atom_man_vs_superman_1950_pt08_serial_into_the_empt0y_doom.avi atom_man_vs_superman_1950_pt09_serial_superman_crashes_through.avi atom_man_vs_superman_1950_pt10_serial_atom_man_s_heat_ray.avi atom_man_vs_superman_1950_pt11_serial_luthors_strategy.avi atom_man_vs_superman_1950_pt12_serial_atom_man_strikes.avi atom_man_vs_superman_1950_pt13_serial_atom_man_s_flying_saucers.avi atom_man_vs_superman_1950_pt14_serial_rocket_of_vengeance.avi atom_man_vs_superman_1950_pt15_serial_superman_saves_the_universe.avi When I copy those to my emby server, they are all shown like separate movies, not additional parts of one movie. Any help appreciated
MBSki 1114 Posted March 20, 2023 Posted March 20, 2023 I think you can just select them all and choose group versions.
0v3rl0rd 5 Posted March 20, 2023 Author Posted March 20, 2023 8 minutes ago, MBSki said: I think you can just select them all and choose group versions. True, but those are not different VERSIONS of one movie - they're PARTS of one movie. I tried to group versions, but then it treats them exactly like different versions - it shows those versions in the dropdown menu. Also, it doesn't automatically play them one after another...
Solution GrimReaper 4851 Posted March 20, 2023 Solution Posted March 20, 2023 (edited) Guess it comes down to naming convention for file stacking and determining what's confusing parser. http://support.emby.media/support/solutions/articles/44001159102-movie-naming Try renaming once or two of those with -ptXX at the end (move other parts out of the movie folder), i.e. superman_1948_theatrical_serial_superman_comes_to_earth-pt01.avi superman_1948_theatrical_serial_dept0hs_of_earth-pt02.avi Rescan, see what gives? If not, try dumping those suffixes (or part of it), i.e. superman_1948-pt01.avi superman_1948-pt02.avi or superman_1948_theatrical_serial-pt01.avi superman_1948_theatrical_serial-pt02.avi Scan again, any change? Edited March 20, 2023 by GrimReaper Rephrased
MBSki 1114 Posted March 20, 2023 Posted March 20, 2023 7 minutes ago, 0v3rl0rd said: True, but those are not different VERSIONS of one movie - they're PARTS of one movie. I tried to group versions, but then it treats them exactly like different versions - it shows those versions in the dropdown menu. Also, it doesn't automatically play them one after another... Right, but as far as I know, whether it's a different version or a part it's handled the same. Did you see it handled differently before? I don't think I ever figured how to get the parts to order 1 after another. Only way I can do that is in a tv show and make them all separate episodes by changing the metadata manually.
GrimReaper 4851 Posted March 20, 2023 Posted March 20, 2023 2 minutes ago, MBSki said: but as far as I know, whether it's a different version or a part it's handled the same. Nope, they're not. If multi-versioned, they're treated exactly like that, different versions of the same item (no continuation/auto-play). If multi-part (file stacking) they are treated as multiple parts and are displayed as such in some client apps UI (and auto-played in sequence).
MBSki 1114 Posted March 20, 2023 Posted March 20, 2023 Just now, GrimReaper said: If multi-part (file stacking) they are treated as multiple parts and are displayed as such in some client apps UI (and auto-played in sequence). Wow, really? Is that just for movies? I've never seen that work in tv shows. What clients does it work on?
GrimReaper 4851 Posted March 20, 2023 Posted March 20, 2023 4 minutes ago, MBSki said: Is that just for movies? AFAIK yes, there's no full support for multi-part episodes (not multi-episode files). 5 minutes ago, MBSki said: What clients does it work on? Again, AFAIK it works in all of them - additional parts are just not displayed in them all (example Web app yes, AndroidTV app no; it does play them, though). 1
0v3rl0rd 5 Posted March 21, 2023 Author Posted March 21, 2023 19 hours ago, GrimReaper said: Guess it comes down to naming convention for file stacking and determining what's confusing parser. http://support.emby.media/support/solutions/articles/44001159102-movie-naming Try renaming once or two of those with -ptXX at the end (move other parts out of the movie folder), i.e. superman_1948_theatrical_serial_superman_comes_to_earth-pt01.avi superman_1948_theatrical_serial_dept0hs_of_earth-pt02.avi Rescan, see what gives? If not, try dumping those suffixes (or part of it), i.e. superman_1948-pt01.avi superman_1948-pt02.avi or superman_1948_theatrical_serial-pt01.avi superman_1948_theatrical_serial-pt02.avi Scan again, any change? The only thing that worked was dumping everything except the main movie name, as follows: superman_1948_pt01.avi superman_1948_pt02.avi etc. Thanks for the suggestion Now it's shown as it should be 2
