dma_k 2 Posted March 20, 2023 Posted March 20, 2023 Dear team, Please take a look at the following errors: 2023-03-20 11:44:25.445 Info HttpClient: GET https://api.themoviedb.org/3/movie/408355?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=alternative_titles,reviews,casts,releases,images,keywords,trailers 2023-03-20 11:44:25.493 Error ProviderManager: TvdbMovieImageProvider failed in GetImageInfos for type Movie *** Error Report *** Version: 4.8.0.12 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.10.0-20-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object. at Tvdb.BaseImageProvider.GetImages(List`1 artworks) at Tvdb.TvdbMovieImageProvider.GetImages(RemoteImageFetchOptions options, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken, IRemoteImageProvider provider, IDirectoryService directoryService, Int32 providerIndex) Source: Tvdb TargetSite: System.Collections.Generic.List`1[MediaBrowser.Model.Providers.RemoteImageInfo] GetImages(System.Collections.Generic.List`1[Tvdb.Artwork]) 2023-03-20 11:44:25.493 Info HttpClient: GET https://webservice.fanart.tv/v3/movies/408355?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4 2023-03-20 11:44:25.539 Error ProviderManager: FanartMovieImageProvider failed in GetImageInfos for type Movie *** Error Report *** Version: 4.8.0.12 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.10.0-20-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: BadGateway at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Fanart.FanartMovieImageProvider.DownloadMovieJson(String id, CancellationToken cancellationToken) at Fanart.FanartMovieImageProvider.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.GetImages(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken, IRemoteImageProvider provider, IDirectoryService directoryService, Int32 providerIndex) Source: Emby.Server.Implementations TargetSite: Void MoveNext() # grep BadGateway /var/log/emby/embyserver.txt | wc -l 18
Luke 42245 Posted March 20, 2023 Posted March 20, 2023 HI, for the bad gateway it could just be that fanart is currently having problems. They do from time to time. If you're behind a VPN you may want to try disabling it.
neik 874 Posted March 20, 2023 Posted March 20, 2023 I had that during the night (European Time) in the logs as well. Might have just been an outage on their end.
Luke 42245 Posted March 20, 2023 Posted March 20, 2023 OK, we'll I've pushed an update to the tvdb plugin to resolve the issue for that. Thanks.
neik 874 Posted March 20, 2023 Posted March 20, 2023 1 hour ago, Luke said: OK, we'll I've pushed an update to the tvdb plugin to resolve the issue for that. Thanks. It was timing out on fanart not on tvdb?! Or is it part of the tvdb plugin anyways?
Luke 42245 Posted March 20, 2023 Posted March 20, 2023 29 minutes ago, neik said: It was timing out on fanart not on tvdb?! Or is it part of the tvdb plugin anyways? He posted about two different things. 1
dma_k 2 Posted March 21, 2023 Author Posted March 21, 2023 19 hours ago, Luke said: He posted about two different things. I agree, I should have made two separate posts. Will information collection from FanartMovieImageProvider be re-run on reindex? Or the retrieval attempt will never be performed for the given movie?
Luke 42245 Posted March 21, 2023 Posted March 21, 2023 8 minutes ago, dma_k said: I agree, I should have made two separate posts. Will information collection from FanartMovieImageProvider be re-run on reindex? Or the retrieval attempt will never be performed for the given movie? No, it does not keep trying again. When something fails like that you'll have to refresh the metadata on it manually if you want it to try again.
