Grumpy1 46 Posted March 19, 2023 Posted March 19, 2023 Hi I always struggle setting up a new PC and getting all the networking stuff to work, it used to be so easy with win 7/8. i run a win 10 pc in the basement with just emby on it and use tightvnc to access it , transferring files from my main pc is always a nightmare because of windows credentials( i don't get this to work since i never set a password on the server pc and windows credentials always asks for one) the main question i guess i have is under ---- Control Panel\Network and Internet\Network and Sharing Center\Advanced sharing settings \ All networks - is it safe to use Turn off Password protected sharing, if i do this everything works perfect but don't know if i am putting my network or anything at risk. I don't share emby outside of the home if that matters any other suggestions are greatly appreciated as well since i dont really get any of the networking stuff Thanks
kikinjo 294 Posted March 19, 2023 Posted March 19, 2023 Since u don't share it out of local network it is fine to do it. Windows 10/11 enforced lot of security stuff on file and print sharing, that's why now its more "complicated" . 2
ebr 16307 Posted March 20, 2023 Posted March 20, 2023 23 hours ago, Grumpy1 said: I don't share emby outside of the home if that matters Do you share anything else on your network?
Grumpy1 46 Posted March 20, 2023 Author Posted March 20, 2023 13 minutes ago, ebr said: Do you share anything else on your network? i do not
