RedWings 15 Posted March 19, 2023 Posted March 19, 2023 (edited) Hello, I don't know why but at every reboot of Emby server. The options subtitle of "Advanced Transcoding" is disable. Now that I know I can live with it, but if this can be fixed in the future i will be happy. Thank you. embyserver.txthardware_detection-63814829120.txt Edited March 19, 2023 by RedWings
Solution ebr 16354 Posted March 19, 2023 Solution Posted March 19, 2023 Hi. Those options are only available via the diagnostics plug-in so they are designed to not be persistent on purpose.
RedWings 15 Posted March 19, 2023 Author Posted March 19, 2023 AH ok ok, didn't know that. no way of making them persistent i suppose ? Because if i don't enable subtitle transcoding my media never play.
pwhodges 2039 Posted March 19, 2023 Posted March 19, 2023 For now you just have to remember to re-enable it after a server restart (this catches me out sometimes, especially after a Windows update!). The functionality is solid enough that it'll surely be in the final 4.8 release - though I would like for it to be made persistent in the beta before then, presumably with an option to turn it off again for test purposes... (not everything in the diagnostics plugin is non-persistent, after all). Paul 1
