thunderclap 52 Posted March 18, 2023 Posted March 18, 2023 A friend has an Apple TV and has reported several movies are playing but only a black screen and no audio. This has happened with both 4k and 1080p MKVs. I've had him try changing quality from auto the lower quality streams but even doing that doesn't help. I'm attaching two diagnostics here to see if someone can spot what is happening. Thank you for any help in resolving the issue. ffmpeg-transcode-87cac34d-88e9-42ab-95eb-95aeeef269c0_1-movie2.txt ffmpeg-transcode-861ae62e-32e1-498b-ac6a-06d9da7c35d3_1-movie1.txt
thunderclap 52 Posted March 18, 2023 Author Posted March 18, 2023 2 minutes ago, Luke said: hi: Now, why didn't that show up when I was searching for it last night? *sigh* Thank you. What will the version number be? Do you have an ETA for the rollout? Thanks as always for being so responsive!
crash1015 5 Posted April 20, 2023 Posted April 20, 2023 Should we expect an update in the next month? Or Is this something you're needing more time on? Not trying to rush, been using Airplay from my iphone as a workaround. Just was curious.
Luke 42240 Posted April 21, 2023 Posted April 21, 2023 8 hours ago, crash1015 said: Should we expect an update in the next month? Or Is this something you're needing more time on? Not trying to rush, been using Airplay from my iphone as a workaround. Just was curious. Yes, next week ideally. 1
crash1015 5 Posted April 25, 2023 Posted April 25, 2023 On 4/20/2023 at 9:09 PM, Luke said: Yes, next week ideally. Thank you so much Luke! You're amazing. 1
