terry331234 0 Posted March 18, 2023 Posted March 18, 2023 Hi, It seems that the preferred subtitle language setting does not work properly for the 3 Chinese options, the behavior below is the same regardless of whether I chose "Chinese Simplified", "Chinese Traditional" or "Chinese Traditional (Hong Kong)" in setting I tested this using videos embedded with different combinations of the 3 subtitle languages: Video contains "Chinese Traditional" & "Chinese Simplified" subs -> "Chinese Simplified" auto selected Video contains "Chinese Traditional (Hong Kong)" & "Chinese Simplified" subs -> "Chinese Traditional (Hong Kong)" auto selected Video contains "Chinese Traditional (Hong Kong)", "Chinese Traditional" and "Chinese Simplified" subs -> "Chinese Traditional (Hong Kong)" auto selected This happens on the web app, android & android TV app The 3 subtitle language for ref: Any help is appreciated!
Luke 42240 Posted March 18, 2023 Posted March 18, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
terry331234 0 Posted March 19, 2023 Author Posted March 19, 2023 Here are the 3 test videos and server log, I used Edge to open the web app If the preferred subtitle language is set to Chinese Traditional, I expect the Chinese Traditional subtitle to be auto selected for 1-cht-chs.mkv and 3-chthk-cht-chs.mkv Thanks 3-chthk-cht-chs.mkv 2-chthk-chs.mkv 1-cht-chs.mkv embyserver.txt
Luke 42240 Posted March 23, 2023 Posted March 23, 2023 Hi, the tracks all have the same language code of zh. The 4.7 server doesn't look at the language name in the track, only the language code. This should be improved in the upcoming 4.8 server release.
