warrentc3 47 Posted March 17, 2023 Posted March 17, 2023 I need to be able to block live tv channels based on tag. This doesn’t appear to work. The user is still able to see and view the channel despite the channel being tagged appropriately and the parental control on the user being defined with a block by tag.
ebr 16307 Posted March 17, 2023 Posted March 17, 2023 Hi. Can we please look at details? Show us some screen shots of how you set this up. Thanks.
Solution warrentc3 47 Posted March 17, 2023 Author Solution Posted March 17, 2023 well, just tried to repro with another local user and the channel is not visible in browser, which is the desired behavior. it may be a client cache issue where the user still sees the channel after applying policy. will keep an eye on it the next few days. thanks @ebr 1
