17732 21 Posted March 17, 2023 Author Posted March 17, 2023 Emby's Android TV software will not play movies without sound, and this mobile phone will have no sound. Emby Android Tv client will transcode the video played by RMVB, and the movie played by 720P264High10 will also transcode, but it will not transcode when it is played by emby Android mobile phone client.
Luke 42243 Posted March 29, 2023 Posted March 29, 2023 Hi, can you please try this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide a log from the android app by following the instructions here: This will tell us how the app is trying to play the content. Thanks !
17732 21 Posted March 30, 2023 Author Posted March 30, 2023 4小时前,卢克说: 嗨,你能试试这个版本吗: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 然后按照此处的说明提供安卓应用程序的日志: 这将告诉我们该应用程序是如何尝试播放内容的。 谢谢! Ok, I can try. 1
17732 21 Posted March 30, 2023 Author Posted March 30, 2023 14 hours ago, Luke said: Hi, can you please try this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide a log from the android app by following the instructions here: This will tell us how the app is trying to play the content. Thanks ! I did a test and found that emby can't be used in the left and right keys, but the up and down keys can be used, and the keyboard can't be used in the search interface.
Solution Luke 42243 Posted March 30, 2023 Solution Posted March 30, 2023 Apologies. This was a regression in yesterday's build. I've uploaded a new one to resolve it. Can you download again from the same url? Thanks.
17732 21 Posted March 30, 2023 Author Posted March 30, 2023 5 hours ago, Luke said: Apologies. This was a regression in yesterday's build. I've uploaded a new one to resolve it. Can you download again from the same url? Thanks. Ok, I'll test it 1
17732 21 Posted March 30, 2023 Author Posted March 30, 2023 6 hours ago, Luke said: Apologies. This was a regression in yesterday's build. I've uploaded a new one to resolve it. Can you download again from the same url? Thanks. I did a test, and I found many problems. Question 1: I can't use the input method in the search interface. Question 2: There is no sound when playing AC3 movies (can I add the option of down-mixing stereo? Question 3: If there is no operating device with a pointer in the initial interface of this app, you can't choose Skip or Next.(I uploaded relevant pictures for question 2 and question 3 respectively.)
17732 21 Posted March 31, 2023 Author Posted March 31, 2023 3 minutes ago, Luke said: What happens when you try to search? There is no keyboard at the bottom. I am from China. We need to input text, but there is no keyboard at the bottom, only a row of English letters at the top. English letters are useless to me.
17732 21 Posted March 31, 2023 Author Posted March 31, 2023 1 hour ago, Luke said: What happens when you try to search? I sent you a video, which shows that the keyboard at the bottom of the search can't be displayed directly. It will only appear if I press the home button of the remote control and then return to emby, which bothers me and I hope to fix this bug. sd1680234576_2.mp4
Luke 42243 Posted March 31, 2023 Posted March 31, 2023 OK thanks, we'll take a look. Regarding the ac3 problem, can you play the content and then provide a log from the app: Thanks !
17732 21 Posted March 31, 2023 Author Posted March 31, 2023 9 minutes ago, Luke said: OK thanks, we'll take a look. Regarding the ac3 problem, can you play the content and then provide a log from the app: Thanks ! ffmpeg-directstream-28146fdb-0c7f-42d1-a739-bb278764ffb8_1.txt
Luke 42243 Posted March 31, 2023 Posted March 31, 2023 4 minutes ago, 17732 said: ffmpeg-directstream-28146fdb-0c7f-42d1-a739-bb278764ffb8_1.txt 54.83 kB · 1 download That's the emby server log. Can you please click the link I gave you to obtain instructions to get a log from the android device? Thanks.
17732 21 Posted March 31, 2023 Author Posted March 31, 2023 12 minutes ago, Luke said: That's the emby server log. Can you please click the link I gave you to obtain instructions to get a log from the android device? Thanks. ed3fb292-5f7b-4e49-ac4f-6d24b79bd62d.log 18b0f423-d83d-4d06-8241-734d238078f5.log d2c4116b-49d0-4ee0-8d70-5e5780af1a46.log 46cf7ac4-c10b-4a79-b153-a73219278a23.log
Luke 42243 Posted March 31, 2023 Posted March 31, 2023 @17732 can you provide a copy of this video for testing? Thanks.
17732 21 Posted March 31, 2023 Author Posted March 31, 2023 (edited) You try. Edited March 31, 2023 by 17732
17732 21 Posted March 31, 2023 Author Posted March 31, 2023 5 hours ago, Luke said: @17732 can you provide a copy of this video for testing? Thanks. am in China, and I downloaded it with Thunder. I don't know if your country is ok. 喜欢你.This.Is.Not.What.I.Expected.2017.HD1080P.X264.AC3.Mandarin.CHS.Adans.torrent
Luke 42243 Posted April 1, 2023 Posted April 1, 2023 Are you sure that’s the video file? It’s only 96k..
17732 21 Posted April 1, 2023 Author Posted April 1, 2023 6 minutes ago, Luke said: Are you sure that’s the video file? It’s only 96k.. The video file is very big, 5G. I sent you the seed.
Luke 42243 Posted April 11, 2023 Posted April 11, 2023 Is it possible to cut a small slice of the video file with mkvtoolnix and then upload that file directly to here?
17732 21 Posted April 14, 2023 Author Posted April 14, 2023 在 2023/4/12 上午6点05分, Luke 说: 是不是可以使用mkvtoolnix 剪切一小部分视频文件,然后将文件直接上传到这里? 喜欢你.This.Is.Not.What.I.Expected.2017.HD1080P.X264.AC3.Mandarin.CHS.Adans.mkv
Luke 42243 Posted April 17, 2023 Posted April 17, 2023 On 4/13/2023 at 9:47 PM, 17732 said: 喜欢你.This.Is.Not.What.I.Expected.2017.HD1080P.X264.AC3.Mandarin.CHS.Adans.mkv 72.16 MB · 2 downloads Hmm, this plays with sound for me. Can you try importing this small slice into your Emby Server. Do you get sound with this sample file?
17732 21 Posted October 7, 2023 Author Posted October 7, 2023 2 minutes ago, wjybing said: i have the same problem that the app 3.3.29 could not play. But it was running when I changed another TV set. I think is it the problem about android Tv app is fleshed? If i need previous version, how can get them? If you also play a movie with dolby pro logic without sound, it is because your device does not support Dolby audio. The only solution is to use other players, such as mxplayer, when playing through emby. The TV version of emby can help you convert Dolby audio to stereo, but the mobile phone version of emby does not support Dolby audio to stereo, so there will be no sound when the device does not support Dolby.
