hjason7812 35 Posted March 13, 2023 Posted March 13, 2023 hello i have an issue where the skip intro feature isn't working. when i run the detect episode intros scan i get the error attached in a text file. i have not been able to figure this out i tried everything from reinstalling the library to the entire server. Also i have two collection libraries in the library section and on my home screen and i can't get rid of them or even one. a delete button on this library would be aswesome btw also i have attached the log file the newest in the logs and yes Luke i do have the cache setup on my server because it runs better this way rather than using the defult cache defult cache is slow for some reason... thank you Detect Episode Intros ERROR.txt embyserver(1).txt
Luke 42237 Posted March 14, 2023 Posted March 14, 2023 Hi, did you roll back and forth between beta and stable by any chance?
