streamac 3 Posted March 12, 2023 Posted March 12, 2023 I have been using double tapping the side to skip ahead but this doesn’t seem to be working anymore with 2.2.7. Has something changed and I should enable it somewhere, or is it a bug?
neik 874 Posted March 12, 2023 Posted March 12, 2023 Not the appropriate topic but somehow similar. Same is valid for Emby for Android, double tap for skipping hasn't been working for a couple of versions now.
Luke 42239 Posted March 21, 2023 Posted March 21, 2023 Hi, we'll take a look at it. Thanks for reporting.
alok1 14 Posted January 6, 2024 Posted January 6, 2024 (edited) On 3/21/2023 at 11:01 PM, Luke said: Hi, we'll take a look at it. Thanks for reporting. Hey! I want to report that Double tap still doesn't work in Emby Android version 3.3.56 and 3.3.58. Thanks. Edited January 6, 2024 by kakashi55 1
Luke 42239 Posted January 14, 2024 Posted January 14, 2024 HI, yes, we'll have to look at how to work this back in. Thanks. 1
Vienna 4 Posted March 1, 2024 Posted March 1, 2024 In the meantime, can there be just the regular 10 sec skip forward/back buttons for music playback? There are for podcasts/audiobooks, but when playing music files those buttons are missing. Only way to move around in a song is to scrub the progress bar which is not ideal
Luke 42239 Posted March 19, 2024 Posted March 19, 2024 On 2/29/2024 at 10:35 PM, Vienna said: In the meantime, can there be just the regular 10 sec skip forward/back buttons for music playback? There are for podcasts/audiobooks, but when playing music files those buttons are missing. Only way to move around in a song is to scrub the progress bar which is not ideal HI, why isn't the progress bar ideal?
Vienna 4 Posted April 1, 2024 Posted April 1, 2024 (edited) On 3/19/2024 at 11:51 AM, Luke said: HI, why isn't the progress bar ideal? Not saying a progress bar itself isn’t ideal, I thought this thread was about the skip forward/back capability, which isn’t present on iOS Emby music player. Currently to skim forward/back on a music track, you have scrub a tiny progress bar. In other Emby libraries, there is an actual “10 sec forward/back” button. It’s even there in podcast playback (and I think every other library. Movies, etc.), just not for music Edited April 1, 2024 by Vienna
Luke 42239 Posted April 3, 2024 Posted April 3, 2024 On 4/1/2024 at 7:18 AM, Vienna said: Not saying a progress bar itself isn’t ideal, I thought this thread was about the skip forward/back capability, which isn’t present on iOS Emby music player. Currently to skim forward/back on a music track, you have scrub a tiny progress bar. In other Emby libraries, there is an actual “10 sec forward/back” button. It’s even there in podcast playback (and I think every other library. Movies, etc.), just not for music It's pretty tall vertically though, no? Is it really tiny?
neik 874 Posted April 3, 2024 Posted April 3, 2024 Tall or not it simply does not replace a 10 second skip in a 2 hours movie. I think we can agree that skipping small amount of time is at least tricky using the progress bar. Besides, this double tap feature was already available (at least in Android) at some point and taken away for whatever reason. Really interesting question would be, why did you take it away in the first place? I assume there was a reason for that, really interested to know. FWIW, on YouTube I use it all the time...
alok1 14 Posted April 4, 2024 Posted April 4, 2024 (edited) 12 hours ago, neik said: Tall or not it simply does not replace a 10 second skip in a 2 hours movie. Actually, Luke is replying for 10 second skip in music playback. 12 hours ago, neik said: FWIW, on YouTube I use it all the time... Double tap to skip without bringing video osd is really a nice feature. I am also wondering why they removed it. Edited April 4, 2024 by kakashi55
Vienna 4 Posted April 6, 2024 Posted April 6, 2024 On 4/3/2024 at 1:24 PM, Luke said: It's pretty tall vertically though, no? Is it really tiny? The progress bar is beside the point, I shouldn’t have even mentioned it. It could be supersized but doesn’t change the fact that skip buttons are missing 1
alok1 14 Posted January 2, 2025 Posted January 2, 2025 On 3/21/2023 at 11:01 PM, Luke said: Hi, we'll take a look at it. Thanks for reporting. Hi, is there any chance that 'Double tap to skip' will come again in Android app ? Thanks
Luke 42239 Posted May 30, 2025 Posted May 30, 2025 On 1/2/2025 at 3:01 PM, alok1 said: Hi, is there any chance that 'Double tap to skip' will come again in Android app ? Thanks Hi, we'll add this back in the next update to the app. Thanks.
