gtali7878 4 Posted March 10, 2023 Posted March 10, 2023 Hello how are you? I have a question, whenever I import my iptv m3u and iptv xml on emby the m3u imports well and I can play the channels but the epg guide never does, it gives me a ton of different errors that usually have to do with connection problems, but it loads well on every other iptv app or software'. but interestingly enough the only way I can get my providers epg guide to load is by first uploading it on xteve (along with the m3u url) and then once Ive mapped the necessary channels I can use the epg guide provided by xteve and upload it into emby and then it recognizes the channels and it brings up the info. I've tried other services like iptveditor.com.and https://xtream-editor.com/ and Ive tried to do the same thing which is upload the urls and then use the new m3u and epg urls that they provide after they run it through their servers but those dont work on emby either, they work on every other m3u app like tivimate and implayer but for whatever reason not emby. Although Im glad that Xteve is an option, unfortunately it doesn't run well on my nas and it seems to use up to many resources so I commonly find that xteve crashes after a few hours or days of use (specially when its updating the info) and of course my iptv service on emby stops working. I know this was a bit long but I asked the question because I don't find any other options, if you know of any other way to upload my epg guide on emby i would appreciate it. If you need my iptv info I can send it to you privately, Thanks in advance!!!
Luke 42242 Posted March 10, 2023 Posted March 10, 2023 Hi, what errors? How to Report a Problem Thanks.
gtali7878 4 Posted March 11, 2023 Author Posted March 11, 2023 (edited) Well here is an example of an error that I commonly get when I try to load the guide: I sent it on the next post because it didnt load propertly here *** Error Report *** Version: 4.8.0.21 Command line: /Volume1/@apps/emby/emby-server/system/EmbyServer.dll -programdata /Volume1/Emby -ffdetect /Volume1/@apps/emby/emby-server/bin/ffdetect -ffmpeg /Volume1/@apps/emby/emby-server/bin/ffmpeg -ffprobe /Volume1/@apps/emby/emby-server/bin/ffprobe -defaultdirectory /mnt/public -updatepackage emby_TOS5_APP_{version}_x86_64.tpk Operating system: Linux version 5.15.59 (root@develop-136) (x86_64-tnas-linux-gnu-gcc.br_real (Buildroot 2022.02-rc1-1-g115ad9c548-dirty) 11.2.0, GNU ld (GNU Binutils) Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: Volume1/@apps/emby/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Data path: /Volume1/Emby Application path: /Volume1/@apps/emby/emby-server/system System.Exception: System.Exception: SKCodec had an error reading /Volume1/Emby/metadata/livetv/db72e576d58cd8a311003d1b3f72e0f6/metadata/poster.png at Emby.Drawing.Skia.SkiaEncoder.GetImageSize(String path) at Emby.Drawing.ImageProcessor.GetImageSizeFromImageEncoders(String path, String format, Boolean requiresOrientation, Boolean logException) Source: Emby.Drawing.Skia TargetSite: System.ValueTuple`2[MediaBrowser.Model.Drawing.ImageSize,System.Nullable`1[MediaBrowser.Model.Drawing.ImageOrientation]] GetImageSize(System.String) Edited March 11, 2023 by gtali7878
gtali7878 4 Posted March 11, 2023 Author Posted March 11, 2023 *** Error Report *** Version: 4.8.0.21 Command line: /Volume1/@apps/emby/emby-server/system/EmbyServer.dll -programdata /Volume1/Emby -ffdetect /Volume1/@apps/emby/emby-server/bin/ffdetect -ffmpeg /Volume1/@apps/emby/emby-server/bin/ffmpeg -ffprobe /Volume1/@apps/emby/emby-server/bin/ffprobe -defaultdirectory /mnt/public -updatepackage emby_TOS5_APP_{version}_x86_64.tpk Operating system: Linux version 5.15.59 (root@develop-136) (x86_64-tnas-linux-gnu-gcc.br_real (Buildroot 2022.02-rc1-1-g115ad9c548-dirty) 11.2.0, GNU ld (GNU Binutils) Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: Volume1/@apps/emby/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Data path: /Volume1/Emby Application path: /Volume1/@apps/emby/emby-server/system System.Exception: System.Exception: SKCodec had an error reading /Volume1/Emby/metadata/livetv/db72e576d58cd8a311003d1b3f72e0f6/metadata/poster.png at Emby.Drawing.Skia.SkiaEncoder.GetImageSize(String path) at Emby.Drawing.ImageProcessor.GetImageSizeFromImageEncoders(String path, String format, Boolean requiresOrientation, Boolean logException) Source: Emby.Drawing.Skia TargetSite: System.ValueTuple`2[MediaBrowser.Model.Drawing.ImageSize,System.Nullable`1[MediaBrowser.Model.Drawing.ImageOrientation]] GetImageSize(System.String)
gtali7878 4 Posted March 11, 2023 Author Posted March 11, 2023 it also commonly puts up the error report announcement followed by this:" Command line: /Volume1/@apps/emby/emby-server/system/EmbyServer.dll -programdata /Volume1/Emby -ffdetect /Volume1/@apps/emby/emby-server/bin/ffdetect -ffmpeg /Volume1/@apps/emby/emby-server/bin/ffmpeg -ffprobe /Volume1/@apps/emby/emby-server/bin/ffprobe -defaultdirectory /mnt/public -updatepackage emby_TOS5_APP_{version}_x86_64.tpk
gtali7878 4 Posted March 11, 2023 Author Posted March 11, 2023 does emby require some type of ffmpeg plugin addtionally I use a terrmaster nas for emby do i need have the multimedia server app installed?
gtali7878 4 Posted March 11, 2023 Author Posted March 11, 2023 And when I load it on my emby thats on my pc it loads but not on the nas
Luke 42242 Posted March 11, 2023 Posted March 11, 2023 7 hours ago, gtali7878 said: it also commonly puts up the error report announcement followed by this:" Command line: /Volume1/@apps/emby/emby-server/system/EmbyServer.dll -programdata /Volume1/Emby -ffdetect /Volume1/@apps/emby/emby-server/bin/ffdetect -ffmpeg /Volume1/@apps/emby/emby-server/bin/ffmpeg -ffprobe /Volume1/@apps/emby/emby-server/bin/ffprobe -defaultdirectory /mnt/public -updatepackage emby_TOS5_APP_{version}_x86_64.tpk Hi there, please attach the complete emby server log. Thanks.
gtali7878 4 Posted March 11, 2023 Author Posted March 11, 2023 16 hours ago, Luke said: Hi there, please attach the complete emby server log. Thanks. embyserver.txt
Luke 42242 Posted March 12, 2023 Posted March 12, 2023 Thanks. What version of Terramaster TOS are you on?
gtali7878 4 Posted March 23, 2023 Author Posted March 23, 2023 On 3/12/2023 at 3:42 PM, Luke said: Thanks. What version of Terramaster TOS are you on? 5.0.35 which is supposedly the latest thanks in advance
Luke 42242 Posted March 29, 2023 Posted March 29, 2023 Hi, please try my suggestion here: Let us know if this helps. Thanks.
