DanielMarch 2 Posted March 10, 2023 Posted March 10, 2023 Hello, I have problems with emby on my synology Nas, it's doing strange things, it takes a long time to open files of all kinds or it doesn't open them and it also keeps thinking a lot and it doesn't work, I'm fine, I don't know why it doesn't work now
Luke 42242 Posted March 10, 2023 Posted March 10, 2023 Hi there, can you please provide a specific example? How to Report a Problem Thanks !
DanielMarch 2 Posted March 10, 2023 Author Posted March 10, 2023 Hello, it seems that my Synology Nas was giving me problems, I returned it and I'm going to get one from QNAP, do you recommend any model?
DanielMarch 2 Posted March 10, 2023 Author Posted March 10, 2023 4 Bays, that has QTS 5, 8 GB of memory, 2.5 Ghz power... I have seen the TS 464/4gb/8gb
GrimReaper 4896 Posted March 10, 2023 Posted March 10, 2023 And what are your transcoding requirements, as I reckon you won't get more than 1-2 4K transcodes on that Jasper Lake Celeron? For few 1080p transcodes it should be OK, though.
DanielMarch 2 Posted March 10, 2023 Author Posted March 10, 2023 I'll go for the 4gb TS464 and expand it to 16gb,thanks
DanielMarch 2 Posted March 14, 2023 Author Posted March 14, 2023 I already have the qnap TS464, which server do I have to install, it seems that it is not ARM
Happy2Play 9811 Posted March 14, 2023 Posted March 14, 2023 (edited) 5 minutes ago, DanielMarch said: I already have the qnap TS464, which server do I have to install, it seems that it is not ARM You would install the Intel 64bit version. Emby Server for QNAP NAS - Emby Note the install instructions. Edited March 14, 2023 by Happy2Play
Solution DanielMarch 2 Posted March 14, 2023 Author Solution Posted March 14, 2023 Thanks, I had to give you permissions for the digital signature 1
