mcln27 2 Posted April 25, 2023 Posted April 25, 2023 Good morning I installed the new beta emby-server-synology72_4.8.0.31_x86_64 and now it seems to work i got the controls back on dsm 7.2 Thanx
mcln27 2 Posted April 25, 2023 Posted April 25, 2023 Update i noticed that if you select a serie you don't get the seasons tabs only a row of al the episodes of al seasons where you can scrol trough
mcln27 2 Posted April 25, 2023 Posted April 25, 2023 15 minutes ago, mcln27 said: Update i noticed that if you select a serie you don't get the seasons tabs only a row of al the episodes of al seasons where you can scrol trough This is the normal layout
mcln27 2 Posted April 25, 2023 Posted April 25, 2023 Just now, mcln27 said: This is the normal layout And this is the Version 4.8.0.31 beta version
Luke 42242 Posted April 25, 2023 Posted April 25, 2023 7 hours ago, mcln27 said: Update i noticed that if you select a serie you don't get the seasons tabs only a row of al the episodes of al seasons where you can scrol trough Have you explored your Emby user display options?
mcln27 2 Posted April 26, 2023 Posted April 26, 2023 Thanx that is a feature that a have never noticed or used must be new then Preferred series display Ok thanx looks much better now 21 hours ago, mcln27 said: This is the normal layout And this is the Version 4.8.0.31 beta version 1
