MikeyMan 8 Posted March 8, 2023 Posted March 8, 2023 Hi all! I notice some huge delays recently. Take quite a long time to build up the home screens. It seems to be limited to two of the three folders i have in the libary. First thought it was down to the LG app. But when i login to the web interface i see the same behavior. Strangely enough all works very quickly afterwards. Just seems to be initial build up. First login: After one minute +: Logs without debug: embyserver.txt Anything else i can do to check?? Just turned it on for later.
seanbuff 1356 Posted March 8, 2023 Posted March 8, 2023 54 minutes ago, MikeyMan said: Anything else i can do to check?? When was the last time you vacuumed your database? Also, if you have ample RAM - you might want to tweak your DB cache size -- see this tutorial: 1 1
MikeyMan 8 Posted March 8, 2023 Author Posted March 8, 2023 @seanbuff you mean delete stuff? Not recently... The NAS should be able to handle it. It's a 1520+. Let me check the cache size.
seanbuff 1356 Posted March 8, 2023 Posted March 8, 2023 26 minutes ago, MikeyMan said: you mean delete stuff? Not at all. Read the note about "vacuum" in the screenshot of that link. 1
MikeyMan 8 Posted March 8, 2023 Author Posted March 8, 2023 (edited) Ah yes, was just working through that. DB size is 272281600, so that's roughly 260mb. After vacuuming its 199626752, so roughly 190mb. So that's a nice 30% decrease. I've upped the cache to 400mb. Lets see how that goes. Edited March 8, 2023 by MikeyMan 1
MikeyMan 8 Posted March 8, 2023 Author Posted March 8, 2023 Seems to be a lot quicker after some tests! Might i ask; why not schedule the vacuum weekly or monthly?
Happy2Play 9811 Posted March 8, 2023 Posted March 8, 2023 1 minute ago, MikeyMan said: Might i ask; why not schedule the vacuum weekly or monthly? There will be a schedule task in 4.8 but it will just enable the flag but still requires you to do a restart.
MikeyMan 8 Posted March 8, 2023 Author Posted March 8, 2023 3 minutes ago, Happy2Play said: There will be a schedule task in 4.8 but it will just enable the flag but still requires you to do a restart. Could also be scheduled of course
Happy2Play 9811 Posted March 8, 2023 Posted March 8, 2023 2 minutes ago, MikeyMan said: Could also be scheduled of course True with a scripted api call or the Restart plugin.
MikeyMan 8 Posted March 8, 2023 Author Posted March 8, 2023 Ok, just started the TV again, and not impressed with the improvement tbh. Will post debug log tomorrow.
Q-Droid 1011 Posted March 8, 2023 Posted March 8, 2023 Where is the emby cache located on your server?
MikeyMan 8 Posted March 8, 2023 Author Posted March 8, 2023 8 minutes ago, Q-Droid said: Where is the emby cache located on your server?
Q-Droid 1011 Posted March 8, 2023 Posted March 8, 2023 Is that SSD or HDD? Emby perf can benefit when internal files (db, cache, metadata) are on SSD. The DB cache settings will help queries though the files still have to be fetched and transferred. So the faster the better. There's also a library setting to download images in advance but to be honest I don't know exactly which images this affects and whether your problem is from fetching them on demand from the source.
MikeyMan 8 Posted March 8, 2023 Author Posted March 8, 2023 @Q-Droidit's HDD on a SHR volume. Should be more than quick enough I would think?
Q-Droid 1011 Posted March 8, 2023 Posted March 8, 2023 Is it still taking minutes to load? HDD alone wouldn't cause it to be that bad. The difference would be sluggish (HDD) vs snappy (SSD). If it's still very slow on multiple clients then gotta keep digging.
Luke 42242 Posted March 8, 2023 Posted March 8, 2023 There are some things that only get loaded once, so yes, it is possible that performance will improve after some internal caches start building up. Did you try adjusting the database options?
MikeyMan 8 Posted March 9, 2023 Author Posted March 9, 2023 Ive turned on debug logging, hope these are the right files. embyserver (1).txt embyserver-63813916800.txt @Luke I understand, but it never was so slow as it is recently. I havent added much more shows/movies in the recent months. So thats why i think something might be wrong here.
Happy2Play 9811 Posted March 9, 2023 Posted March 9, 2023 Yes I see you changed your db cache size to 400. Not sure where the metatata delete is coming from. Lines 304 thu 123217 in embyserver-63813916800.txt But look like you have having a DLNA issue also. 2023-03-08 21:11:45.915 Error App: Error sending socket message from 0.0.0.0:1900 to 239.255.255.250:1900 *** Error Report *** Version: 4.7.11.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk -noautorunwebapp Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42962 SMP Fri Feb 10 16:34:59 CST 2023 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Net.Sockets.SocketException: System.Net.Sockets.SocketException (101): Network is unreachable at Rssdp.SsdpCommunicationsServer.SendFromSocket(Tuple`3 socketTuple, Memory`1 messageData, IPEndPoint destination, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void Throw() There appear to be long response times for Latest and Resume but not as described above. 2023-03-08 20:51:20.124 Debug Server: http/1.1 Response 200 to host3. Time: 1459ms. http://10.0.0.4:8096/emby/Users/ddee606b06d84b2ea80c7133307a4d1b/Items/Latest?Limit=16&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear,Status,EndDate&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&ParentId=9&X-Emby-Client=Emby for LG&X-Emby-Device-Name=LG Smart TV (OLED55C9PLA)&X-Emby-Device-Id=3e8b1687-9be9-420a-8618-5bf57cc14bc8&X-Emby-Client-Version=1.0.37 2023-03-08 20:51:20.128 Debug Server: http/1.1 Response 200 to host3. Time: 1468ms. http://10.0.0.4:8096/emby/Users/ddee606b06d84b2ea80c7133307a4d1b/Items/Resume?Recursive=true&Fields=BasicSyncInfo,CanDelete,Container,PrimaryImageAspectRatio,ProductionYear&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&MediaTypes=Video&Limit=12&X-Emby-Client=Emby for LG&X-Emby-Device-Name=LG Smart TV (OLED55C9PLA)&X-Emby-Device-Id=3e8b1687-9be9-420a-8618-5bf57cc14bc8&X-Emby-Client-Version=1.0.37 But devs will have to comment more.
Luke 42242 Posted March 10, 2023 Posted March 10, 2023 15 hours ago, MikeyMan said: Ive turned on debug logging, hope these are the right files. embyserver (1).txt 52.85 kB · 3 downloads embyserver-63813916800.txt 15.92 MB · 3 downloads @Luke I understand, but it never was so slow as it is recently. I havent added much more shows/movies in the recent months. So thats why i think something might be wrong here. Have you configured the library scan to run when starting up the server? If you have, then you may want to undo that if it's impacting performance.
MikeyMan 8 Posted March 10, 2023 Author Posted March 10, 2023 10 hours ago, Happy2Play said: Not sure where the metatata delete is coming from. Don't know either. Didn't delete anything manually. 10 hours ago, Happy2Play said: There appear to be long response times for Latest and Resume but not as described above. Strangely enough the Resume category shows up first. Well before the rest of the content. 10 hours ago, Luke said: Have you configured the library scan to run when starting up the server? If you have, then you may want to undo that if it's impacting performance. Don't think so. These are the schedules: I only restart the NAS when an update needs it to.
RobsterUK 23 Posted March 10, 2023 Posted March 10, 2023 On 08/03/2023 at 09:36, seanbuff said: When was the last time you vacuumed your database? Also, if you have ample RAM - you might want to tweak your DB cache size -- see this tutorial: Sorry to hijack the thread. The title drew me in as I have noticed a delay in app loading times in recent months. It has been taking longer to display the library items and home screen in all apps (Theatre for Windows, LG app, Web app, Android app). My library DB was 200MB. I ran the 'vacuum' option and restarted. This reduced the DB to 180MB. I then increased the RAM from the default 96MB to 380MB. Restarted the server again. All apps are responding much faster with the initial loading times & generally feel more zippy. Thanks for posting this. @MikeyManI hope you get your issue resolved 1
