PeterEr 2 Posted March 7, 2023 Posted March 7, 2023 I am launching Emby normally from start menu. After 10-20 seconds EmbyServer.exe crashes and I can of course not browse the site at 8096. Ports are open in Windows firewall. Nothing out of the ordinary in the server logs as far as I can see. Using the latest binaries - tried with 4.8.0.21 and 4.7.11.0. Have uninstalled/reinstalled. Used ccleaner to remove any left overs. Restarted the pc. Running on a Windows 11 Pro, 64 Gb DDR5 ram, 1TB SSD Samsung 990 PRO. CPU is an i9-12950HX. In any case, shouldn't Emby be upgraded to .NET 7 instead .NET 6? From Windows Event Viewer: 1st entry Application: EmbyServer.exe CoreCLR Version: 6.0.1022.47605 .NET Version: 6.0.10 Description: The process was terminated due to an internal error in the .NET Runtime at IP 00007FF8F270224B (00007FF8F2530000) with exit code c0000005. 2nd entry Faulting application name: EmbyServer.exe, version: 4.8.0.21, time stamp: 0x6331eb0e Faulting module name: coreclr.dll, version: 6.0.1022.47605, time stamp: 0x6331e1bc Exception code: 0xc0000005 Fault offset: 0x00000000001d224b Faulting process id: 0x0x3BC8 Faulting application start time: 0x0x1D95118DBAE88B1 Faulting application path: C:\Users\myusername\AppData\Roaming\Emby-Server\system\EmbyServer.exe Faulting module path: C:\Users\myusername\AppData\Roaming\Emby-Server\system\coreclr.dll Report Id: 48b6cd8d-758c-4817-9c56-8dd8dcd10781 Faulting package full name: Faulting package-relative application ID: 4.7.11.0 Faulting application name: EmbyServer.exe, version: 4.7.11.0, time stamp: 0x6331eb0e Faulting module name: coreclr.dll, version: 6.0.1022.47605, time stamp: 0x6331e1bc Exception code: 0xc0000005 Fault offset: 0x00000000001d224b Faulting process id: 0x0x5114 Faulting application start time: 0x0x1D951146B8DA54B Faulting application path: C:\Users\myusername\AppData\Roaming\Emby-Server\system\EmbyServer.exe Faulting module path: C:\Users\myusername\AppData\Roaming\Emby-Server\system\coreclr.dll Report Id: 45437614-1545-413e-8f07-71edf8603ef8 Faulting package full name: Faulting package-relative application ID: embyserver-63813812084.txt embyserver-63813812933.txt
Luke 42186 Posted March 7, 2023 Posted March 7, 2023 Hi, based on the error code, please let us know if the solutions in these topics helps at all:
PeterEr 2 Posted March 7, 2023 Author Posted March 7, 2023 This points to a problem with the Intel ARC drivers. I do have an Intel Arc Pro A30M in this machine. Latest drivers are 31.0.101.4091 for me. There is 4146 version out / other people indicates problems here too: https://community.intel.com/t5/Graphics/ARC-A770-is-killing-my-audio/td-p/1443864 1
