MAX92 93 Posted April 18, 2023 Author Posted April 18, 2023 @LukeI have Emby app on the TV. So it is possible but for me it doesn't work
Luke 42239 Posted April 18, 2023 Posted April 18, 2023 35 minutes ago, MAX92 said: @LukeI have Emby app on the TV. So it is possible but for me it doesn't work Make sure the Emby app is running and then you can cast to it.
MAX92 93 Posted April 25, 2023 Author Posted April 25, 2023 I try one more time, the Emby App is running on the TV but when I can't cast on it, I have not the device on my phone. (I have no device). However, I can cast with youtube
Luke 42239 Posted April 25, 2023 Posted April 25, 2023 38 minutes ago, MAX92 said: I try one more time, the Emby App is running on the TV but when I can't cast on it, I have not the device on my phone. (I have no device). However, I can cast with youtube What Emby app is running on the TV? What version? Are both Emby apps signed in with the same user?
MAX92 93 Posted April 25, 2023 Author Posted April 25, 2023 No the both Apps are not signed with the same user. Is it important ?
Luke 42239 Posted April 25, 2023 Posted April 25, 2023 16 minutes ago, MAX92 said: No the both Apps are not signed with the same user. Is it important ? Depends. Have you checked the remote control permissions for the user on the phone?
MAX92 93 Posted April 30, 2023 Author Posted April 30, 2023 I have donne some new tests. I can cast on a freetv box without installing EMBY. What is the thing you must have to cast emby on a device ?
Luke 42239 Posted May 13, 2023 Posted May 13, 2023 On 4/26/2023 at 2:53 AM, MAX92 said: What I have to check ? What option ? In Emby Server user management "allow this user to remote control other users".
