ross87 12 Posted March 2, 2023 Posted March 2, 2023 Hi, I've been trying to setup CloudFlare DDNS and a SSL certificate for Emby. I've successfully setup DDNS, however when I added the certificate to EMBY and started the server, I'm now unable to access EMBY at all (locally or externally). Is there any way around this? Is there a way of removing the SSL without access to the web based GUI? Thanks in advance.
ross87 12 Posted March 2, 2023 Author Posted March 2, 2023 I've managed to bypass it by deleting system.xml - now to just work out what caused that!
Happy2Play 9800 Posted March 2, 2023 Posted March 2, 2023 Can only guess changes you made on the Network page. But yes it is not hard to do. Just have to remember your changes and only change that area of the system.xml file. 1
ross87 12 Posted March 2, 2023 Author Posted March 2, 2023 35 minutes ago, Happy2Play said: Can only guess changes you made on the Network page. But yes it is not hard to do. Just have to remember your changes and only change that area of the system.xml file. Yeah it was definitely that. No idea what though but I'll try again, backing up the system file first! 1
