palight 0 Posted March 2, 2023 Posted March 2, 2023 Hi, I just bought this pair of speaker with support DLNA. When I launch an album on it from emby, it just stop playing after each song and no playlist is created. I can't neither control volume. I also tried to discover emby DLNA server from the speaker, but it doesn't work (minidlna does perfectly). What do I need to do to resolve this two problems ? Thanks by advance for your help
Luke 42237 Posted March 2, 2023 Posted March 2, 2023 Quote I also tried to discover emby DLNA server from the speaker, but it doesn't work (minidlna does perfectly). Hi, what exactly happens?
palight 0 Posted March 2, 2023 Author Posted March 2, 2023 2 minutes ago, Luke said: Hi, what exactly happens? It doesn't show as a server. I activated dlna and in the app from my speakers it doesn't appear. Maybe it is not my main concern the first problem is the worst.
Luke 42237 Posted March 5, 2023 Posted March 5, 2023 Quote When I launch an album on it from emby, it just stop playing after each song and no playlist is created. I can't neither control volume. can you please attach the emby server log from when you tried to do this? How to Report a Problem Thanks.
palight 0 Posted March 13, 2023 Author Posted March 13, 2023 Hi , Here is the log from the last hours with a try to launch an album on the last lines. Will try to do the same with jellyfin and report if success. Thanks for your feedback ! embyserver.txt
palight 0 Posted March 13, 2023 Author Posted March 13, 2023 It works partially on jellyfin as the whole album will play, but I can't control the speakers from it nor edit the playlist
Luke 42237 Posted March 14, 2023 Posted March 14, 2023 Did you enable the Dlna Server in Emby Server DLNA settings?
palight 0 Posted March 14, 2023 Author Posted March 14, 2023 nope, i justed tried with dlna server activated, but same beglhaviour occur. here is the log with dlna server activated. embyserver.txt
Luke 42237 Posted March 21, 2023 Posted March 21, 2023 @palight can you produce a new log file, but this time temporarily enable debug logging in Emby Server log settings? I'd like to see the debug log. Thanks !
