cncb 25 Posted March 1, 2023 Posted March 1, 2023 I noticed that the Cast (actors) section in Kodi is empty when using EmbyCon. Is it possible for this information to be supplied to Kodi for display? Thanks.
TeamB 2440 Posted March 1, 2023 Posted March 1, 2023 There are two ways to do this. 1. If you use the "Estuary (EmbyCon)" Skin, this is the one that gets installed when you install the EmbyCon addon then the cast is displayed on the Video Info dialog automatically. 2. If you want to use a different skin you can show CAST by having EmbyCon include and add the cast/people when the page is loaded. EmbyCon->Settings->Interface->Include People Option 2: turning on Include People will slow down browsing as it needs to include the people in the request from the emby server, process all the people and add them to all the items on the page even if you want want to view them. Also if you turn on Include Poeple you will need to clear your saved Emby Server cached data under the EmbyCon addon action menu.
cncb 25 Posted March 2, 2023 Author Posted March 2, 2023 On 2/28/2023 at 11:51 PM, TeamB said: Also if you turn on Include Poeple you will need to clear your saved Emby Server cached data under the EmbyCon addon action menu. This is what I was missing. Thanks!
