conchoaz 1 Posted February 28, 2023 Posted February 28, 2023 I recently moved to a new address and now I can't connect my Emby to my Roku any longer. I tried Emby Connect and it shows that pin was accepted but Roku asks me to enter IP address which I have done but it doesn't accept and won't connect. I even tried connecting using the out of network IP and still no luck. Everything else connects to Roku fine, even Plex which I don't like to use.
ebr 16334 Posted March 1, 2023 Posted March 1, 2023 18 hours ago, conchoaz said: I recently moved to a new address Hi. What exactly moved? The server location or just the Roku device? Have you confirmed the server addresses are correct and that remote access is setup properly (if this is remote)?
