kooapk 12 Posted February 28, 2023 Posted February 28, 2023 I installed emby in windows wsl2 and docker mode. My graphics card is nvidia GPX 960 First of all, I installed the special driver that wsl2 can use the gpu https://developer.nvidia.com/cuda/wsl nvidia-smi Wed Mar 1 00:59:12 2023 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 515.65.01 Driver Version: 516.94 CUDA Version: 11.7 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 NVIDIA GeForce ... On | 00000000:2B:00.0 On | N/A | | 36% 32C P8 14W / 120W | 1623MiB / 2048MiB | 4% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | 0 N/A N/A 21 G /Xwayland N/A | +-----------------------------------------------------------------------------+ docker run -d \ --name=emby \ -p 8096:8096 \ -p 8920:8920 `#optional` \ -p '1900:1900/udp' \ -p '7359:7359/udp' \ -v /root/kooapk/docker/emby/config:/config \ -v /mnt/wsl/raid5/video:/video \ -v /opt/vc/lib:/opt/vc/lib `#optional` \ --device /dev/dri:/dev/dri `#optional` \ -e PUID=0 \ -e PGID=0 \ --mac-address=d8:bb:c1:38:d0:1e \ -e TZ="Asia/Shanghai" \ --restart always \ lscr.io/linuxserver/emby:latest Emby did not detect gpu. I need your help. thank you
Solution Luke 42245 Posted February 28, 2023 Solution Posted February 28, 2023 Hi, have you taken a look at the GPU notes in our Docker setup guide? https://hub.docker.com/r/emby/embyserver Have you tried our official Docker container rather than linuxserver? https://emby.media/docker-server.html
kooapk 12 Posted March 1, 2023 Author Posted March 1, 2023 Thank you for the solution. Since there is a problem with Linux server's emby. Why is it released. So many people still use it
kooapk 12 Posted March 1, 2023 Author Posted March 1, 2023 https://docs.nvidia.com/datacenter/cloud-native/container-toolkit/install-guide.html#docker
kooapk 12 Posted March 1, 2023 Author Posted March 1, 2023 docker run -d \ --name=emby \ --network=bridge \ -p 8096:8096 \ -p 8920:8920 `#optional` \ -p '1900:1900/udp' \ -p '7359:7359/udp' \ -v /root/kooapk/docker/emby/config:/config \ -v /mnt/wsl/raid5/video:/video \ --device /dev/dri:/dev/dri `#optional` \ --gpus all \ -e PUID=0 \ -e PGID=0 \ -e GIDLIST=0 \ --mac-address=d8:bb:c1:38:d0:1e \ -e TZ="Asia/Shanghai" \ --restart always \ emby/embyserver:latest
kooapk 12 Posted March 1, 2023 Author Posted March 1, 2023 I don't have nvidia-container-toolkit installed by nvidia-container-runtime
Luke 42245 Posted March 17, 2023 Posted March 17, 2023 @kooapk were you able to resolve this? have you taken a look at the GPU notes in our Docker setup guide? https://hub.docker.com/r/emby/embyserver
