marshall409 1 Posted February 28, 2023 Posted February 28, 2023 Should I expect any difference in reliability - particularly with recording shows - when using xTeve buffer on or off?
Luke 42242 Posted February 28, 2023 Posted February 28, 2023 Hi, we generally suggest not to buffer as Emby Server will usually also have it's own.
marshall409 1 Posted February 28, 2023 Author Posted February 28, 2023 Perfect thanks. Also wanted to ask lets say I had a spotty connection to the IPTV server and Emby loses the connection in the middle of a manually scheduled recording (time and channel), will it continuously try to reconnect and restart the recording?
Luke 42242 Posted February 28, 2023 Posted February 28, 2023 2 hours ago, marshall409 said: Perfect thanks. Also wanted to ask lets say I had a spotty connection to the IPTV server and Emby loses the connection in the middle of a manually scheduled recording (time and channel), will it continuously try to reconnect and restart the recording? Yes it will.
RobDenny 9 Posted February 28, 2023 Posted February 28, 2023 3 hours ago, Luke said: Yes it will. Not in my experience Luke. If the provider goes down it gives up really quickly, and doesn't continue recording.
Luke 42242 Posted February 28, 2023 Posted February 28, 2023 12 hours ago, RobDenny said: Not in my experience Luke. If the provider goes down it gives up really quickly, and doesn't continue recording. The main thing the Emby buffer does is allow the single stream to be used across multiple clients and/or recording at the same time. A provider disconnection may still interrupt recordings although it will retry when this happens.
