Lomnar 0 Posted October 17, 2014 Posted October 17, 2014 First, here is my Setup: Intel Atom D525, 4 GB RAM, 1 TB HDD, Ion Chipsatz, BS: Ubuntu 14.04 LTS I installed the Ubuntu beta *.deb. Version from Mediabrowser Server: 3.0.5380.30224 Now i show you my Problem, i make some Screenshots, so you can see what i mean. i also attached the last log, so if you find any errors, so please let me know Log.zip
ebr 16344 Posted October 17, 2014 Posted October 17, 2014 Yeah, that is a known issue on linux systems with that particular image. It is a transparent reflection that, for some reason, does not work on linux systems. Other than remove the overlay, I'm not sure what to do about it.
techywarrior 689 Posted October 17, 2014 Posted October 17, 2014 haha, I just went to play around with CoverArt because I see you added a "MetroCover" which I thought was pretty cool looking so I thought maybe I'd change (and I guess I am going to have the overlay issue with new stuff?) but I got this error when I selected MetroCover: The requested FontFamily could not be found [GDI+ status: FontFamilyNotFound] Not totally suprising that I am missing a font since I am running on unRAID and it's kept pretty bare bones but the error doesn't even list which font is missing. Can you tell me the font to install, add the font to the error message, or make it so the fonts are automatically installed (prob not possible) ?
ebr 16344 Posted October 17, 2014 Posted October 17, 2014 That's not my error message so I can't change it but the only fonts referenced are "Segoe UI", "Impact", and "Ariel". The problem one is probably the Segoe.
Lomnar 0 Posted October 17, 2014 Author Posted October 17, 2014 ok, thanks for the answer...so i'm waiting until the bug is fixed ;-)
