Chillout 111 Posted February 26, 2023 Posted February 26, 2023 Does Windows ET have an option to normalize audio (ie. dialog enhancer, night mode, DRC, etc) similar to the Roku app? If not, are there any suggestions to replicate the same functionality? The windows 10 built-in sound enhancements are too limited in feature.
Solution Guest Posted February 27, 2023 Solution Posted February 27, 2023 It has all of the options that ffmpeg has, because that's what mpv is built on. But if you want to use audio passthrough, then DRC is only available for AC3. For mpv AC3 DRC: https://mpv.io/manual/master/#options-ad-lavc-ac3drc Using ffmpeg directly: https://ffmpeg.org/ffmpeg-filters.html#dynaudnorm
Chillout 111 Posted February 27, 2023 Author Posted February 27, 2023 Thank you. Looking for a place in ET to add command settings I noticed that being able to adjust DRC is a built-in feature under the Audio settings in the app. So I think this what I was looking for. Thanks for pointing me in the right direction!
Guest Posted February 27, 2023 Posted February 27, 2023 3 hours ago, Chillout said: Thank you. Looking for a place in ET to add command settings I noticed that being able to adjust DRC is a built-in feature under the Audio settings in the app. So I think this what I was looking for. Thanks for pointing me in the right direction! You can make an mpv.conf and add the commands to that.
