Ronstang 294 Posted February 25, 2023 Posted February 25, 2023 This happens occasionally but it usually sorts itself out but I have no guide at all so that is a problem. Two auto refreshes failed this morning and the manual one I just ran failed. I have included the log file. Thanks embyserver.txt
ebr 16307 Posted February 25, 2023 Posted February 25, 2023 Hi. Try this: https://support.emby.media/support/solutions/articles/44002210894-corrupt-database
Ronstang 294 Posted February 25, 2023 Author Posted February 25, 2023 Thanks, figured it out in the wee hours.....already fixed. I need to replace this SSD as this keeps happening every couple weeks....only thing I can think of that can be causing this since it just started happening and this system disk is an old small SATA SSD I used for a long time as a temp directory so it has had a lot written to it over the years. 1
