Sentinel 12 Posted February 22, 2023 Posted February 22, 2023 Hi all, Bit of a long shot, but.... I have got the Emby for Android sideloaded on my shield as well as the Android TV version. I would like to know if there are a couple of things that i can bet back on the Emby for Android on the shield that the Android TV version has. When playing something in Android TV, if long press the button on shield remote, it brings up stats for nerds, but have to navigate menu to turn it on or off in Emby for Android. I know most people hate it, but the sound when navigating on the Android tv version isn't present in the Emby for Android version. When in a browsing in Emby for Android, it displays the highlighted item with a white boarder, but in the options it is get the green, But, the sound and subs, if selectable are green. Can these bits be changed in the Emby for Android verion on the shield? the Emby for Android does display a lot nicer in some ways as well. Also, does the Android version use the css that's changeable on the server for display at all or is that just for the web browser version? Cheers
Luke 42245 Posted February 23, 2023 Posted February 23, 2023 Quote When in a browsing in Emby for Android, it displays the highlighted item with a white boarder, but in the options it is get the green, But, the sound and subs, if selectable are green. Hi, this isn't tied to the accent color. The sounds and subs haven't been changed to white yet, but they will be.
