BuzStringer 33 Posted February 22, 2023 Posted February 22, 2023 I know we can turn on missing episodes, but that makes my libary look a bit messy. is there a way to to display when the next episode of a TV show is due to air prehaps within the show? or is there a plugin that can do this?
Luke 42186 Posted February 22, 2023 Posted February 22, 2023 Hi there, have you explored the Upcoming section of your TV library?
GrimReaper 4851 Posted February 22, 2023 Posted February 22, 2023 (edited) 5 minutes ago, BuzStringer said: prehaps within the show No, but they should show under Upcoming tab of your TV show library. Edited February 22, 2023 by GrimReaper Cross-posted
BuzStringer 33 Posted February 22, 2023 Author Posted February 22, 2023 36 minutes ago, GrimReaper said: No, but they should show under Upcoming tab of your TV show library. Upcoming is quite usefull, but not for shows that are more than a couple of weeks out, or for when things are returning after a mid-season break.
GrimReaper 4851 Posted February 22, 2023 Posted February 22, 2023 5 minutes ago, BuzStringer said: Upcoming is quite usefull, but not for shows that are more than a couple of weeks out, or for when things are returning after a mid-season break. Then you should take a look at *arr app (or equivalent) for tracking.
BuzStringer 33 Posted February 22, 2023 Author Posted February 22, 2023 That's another step and another interface that isn't friendly for other users. plus i dont want anyone else messing around with those. Nevermind, thanks anyway
Happy2Play 9800 Posted February 22, 2023 Posted February 22, 2023 Sort of as it depends on how far out TVDB has data for, and you have User-Display setting "Display missing episodes within seasons" enabled as it plays off of Upcoming. This is not the same as the setting per library. Yours will show Unaired. If TVDB has episode/air date Emby will have it per show as a Virtual db item.
justinrh 264 Posted February 25, 2023 Posted February 25, 2023 It looks like Upcoming shows only never-aired episodes. It is not showing upcoming repeats. FYI.
Luke 42186 Posted March 2, 2023 Posted March 2, 2023 On 2/24/2023 at 7:25 PM, justinrh said: It looks like Upcoming shows only never-aired episodes. It is not showing upcoming repeats. FYI. Correct due to being based on tvdb data.
