pwhodges 2033 Posted January 7, 2024 Posted January 7, 2024 5 hours ago, damien_c2 said: Im not sure it what you need: I have one file in AAC (English and French) on mp4 and even if we select French the roku keep playing english. This behaviour may depend on flags in the file; providing the log for the time of playing may give the information to help resolve this. Paul
ebr 16333 Posted January 7, 2024 Posted January 7, 2024 5 hours ago, pwhodges said: This behaviour may depend on flags in the file; providing the log for the time of playing may give the information to help resolve this. Paul Correct. In an mp4 I believe the Roku is always going to play an audio track that is marked as "default". Can you please check the flags in the file? Thanks.
Grimmer 15 Posted January 7, 2024 Author Posted January 7, 2024 (edited) Requested info... Please let me know if there is something else that will help. At all times it played the English track through the home theater speakers. embyserver-63840226119.txt ffprobetext.txt Edited January 7, 2024 by Grimmer
roaku 842 Posted January 7, 2024 Posted January 7, 2024 (edited) I don't think Rokus can handle dts in mp4s because the container doesn't officially support it and misbehave because of it. I was experiencing this weird behavior and switched to mkv after having the issue explained to me here. I'll try to dig up the thread. Edit: Here's the thread from my encounter with the issue with Roku, DTS, and MP4: Edited January 7, 2024 by roaku
Grimmer 15 Posted January 7, 2024 Author Posted January 7, 2024 I was looking into that as well... Got this from the Roku website: I changed the container to MKV and the audio selections are working from the Roku. However, the stats for nerds is not updating. I even turned the stats off and back on again but they were still out of sync. Despite the stats for nerds stating English, the audio was Spanish. It seems the problem has been uncovered and not difficult to fix with a little ffmpeg action... ffmpeg -i input.mp4 -map 0 -map -d -c:v copy -c:a copy output.mkv -map 0 instructs to do all streams (otherwise it will only copy the default audio track) -map -d instructs to skip the data stream that any .mp4 with chapter markers will have (otherwise it will error) -c:v copy instructs to copy the video without transcoding -c:a copy instructs to copy the audio without transcoding
ebr 16333 Posted January 8, 2024 Posted January 8, 2024 18 hours ago, Grimmer said: However, the stats for nerds is not updating. Hi. How long did you wait?
speechles 2062 Posted January 8, 2024 Posted January 8, 2024 @ebrIt is possible during Direct Play that the stats may be incorrect. On GH #1503 and #1513 explain it better.
