Martini 1 Posted May 23, 2023 Author Posted May 23, 2023 I tried a beta a few weeks ago with the same hanging on 99%. I didn’t check the Roku app for an update so maybe that was an issue? chad
Luke 42240 Posted May 24, 2023 Posted May 24, 2023 1 hour ago, Martini said: I tried a beta a few weeks ago with the same hanging on 99%. I didn’t check the Roku app for an update so maybe that was an issue? chad There has been a change since then that could have an impact, just in case you might like to try again.
Martini 1 Posted May 27, 2023 Author Posted May 27, 2023 Thanks again, can someone help me with a link to the beta download? I found a reference to the release notes and a very long list of files with extensions I don't recognize or understand.
ebr 16334 Posted May 27, 2023 Posted May 27, 2023 Hi. The beta (of the server) is available right on the normal web site. https://emby.media/download
Martini 1 Posted May 29, 2023 Author Posted May 29, 2023 Interesting result with Beta. Starting from beginning, still hangs on 99% but if I start at a chapter in the middle of the video, it works and I rewind almost to the beginning and play. I wonder if it has something to do with how I encoded the disc?
Luke 42240 Posted May 30, 2023 Posted May 30, 2023 22 hours ago, Martini said: Interesting result with Beta. Starting from beginning, still hangs on 99% but if I start at a chapter in the middle of the video, it works and I rewind almost to the beginning and play. I wonder if it has something to do with how I encoded the disc? HI, can we please see an example? thanks.
Martini 1 Posted May 30, 2023 Author Posted May 30, 2023 Thank again for keeping tabs on this. Do you mean some kind of code dump or like a video of the TV while I'm playing a show?
Luke 42240 Posted May 31, 2023 Posted May 31, 2023 23 hours ago, Martini said: Thank again for keeping tabs on this. Do you mean some kind of code dump or like a video of the TV while I'm playing a show? No, just a server/ffmpeg log example would be great. thanks !
Martini 1 Posted June 4, 2023 Author Posted June 4, 2023 I may have learned something new. I have two TV shows that I've loaded into Emby. Scooby Doo and The Andy Griffith Show. Scooby Doo now loads and plays as expected, but the Andy Griffith Show only lets me play if I start at a chapter. If I play from beginning, it just hangs. I bought the discs on Ebay so maybe they are quirky or the conversion from disc to digital was bad. Anyway, I download three of the log files. Hopefully they mean something. Thanks ffmpeg-directstream-d9bad8e8-b234-4aa7-9135-3072eda23d6f_1.txt ffmpeg-directstream-ad771c74-1cb8-4eb0-965f-9874d1a6ce7f_1.txt ffmpeg-directstream-8cd16acc-6fd2-485d-b71a-fd50f05b0028_1.txt
Luke 42240 Posted June 4, 2023 Posted June 4, 2023 That’s interesting. Thanks for the update. We’ll take a look.
