hotwill 3 Posted February 17, 2023 Posted February 17, 2023 (edited) Play fail after play a few minutes. I check the log and find the Transcode error. Here is the emby log: 2023-02-16 12:22:42.390 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 1,251.00 bytes Graph Count: 1 2023-02-16 12:22:42.390 Info App: AppendExtraLogData - File Deleted 2023-02-16 12:22:42.391 Info App: ProcessRun 'StreamTranscode 8be24c' Process exited with code 1 - Failed 2023-02-16 12:22:47.080 Info Server: http/1.1 POST http://emby.xxxxxx.xx/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Android&X-Emby-Device-Name=Hotwill的Xiaomi 12&X-Emby-Device-Id=dc77996ed710ef9a&X-Emby-Client-Version=3.2.92&X-Emby-Language=zh-cn&reqformat=json. UserAgent: Mozilla/5.0 (Linux; Android 12; 2201123C Build/SKQ1.211006.001; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/109.0.5414.118 Mobile Safari/537.36 2023-02-16 12:22:47.080 Info Server: http/1.1 Response 204 to x.xxx.xxx.38. Time: 1ms. http://emby.xxxxxx.xx/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Android&X-Emby-Device-Name=Hotwill的Xiaomi 12&X-Emby-Device-Id=dc77996ed710ef9a&X-Emby-Client-Version=3.2.92&X-Emby-Language=zh-cn&reqformat=json 2023-02-16 12:22:51.499 Info Server: http/1.1 Response 500 to x.xxx.xxx.38. Time: 9920ms. http://emby.xxxxxx.xx/emby/videos/311299/hls1/main/138.ts?PlaySessionId=c74f6c74bd62450d82704aa64ba37725 2023-02-16 12:22:52.153 Info Server: http/1.1 POST http://emby.xxxxxx.xx/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Android&X-Emby-Device-Name=Hotwill的Xiaomi 12&X-Emby-Device-Id=dc77996ed710ef9a&X-Emby-Client-Version=3.2.92&X-Emby-Language=zh-cn&reqformat=json. UserAgent: Mozilla/5.0 (Linux; Android 12; 2201123C Build/SKQ1.211006.001; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/109.0.5414.118 Mobile Safari/537.36 2023-02-16 12:22:52.154 Info Server: http/1.1 Response 204 to x.xxx.xxx.38. Time: 1ms. http://emby.xxxxxx.xx/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Android&X-Emby-Device-Name=Hotwill的Xiaomi 12&X-Emby-Device-Id=dc77996ed710ef9a&X-Emby-Client-Version=3.2.92&X-Emby-Language=zh-cn&reqformat=json 2023-02-16 12:22:52.505 Info Server: http/1.1 GET http://emby.xxxxxx.xx/emby/videos/311299/hls1/main/138.ts?PlaySessionId=c74f6c74bd62450d82704aa64ba37725. Host=emby.hotwill.cn, User-Agent=Emby/3.2.92 (Linux;Android 12) ExoPlayerLib/2.18.2, Accept-Encoding=identity, X-Real-IP=1.202.162.38, X-Forwarded-For=1.202.162.38 2023-02-16 12:22:52.517 Info App: ProcessRun 'StreamTranscode 51cd29' Execute: D:\programs\embyserver-win-x64-3.5.3.0\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "D:\programs\embyserver-win-x64-3.5.3.0\programdata\logs\ffmpeg-transcode-51cd2929-52da-45f0-a0ed-b40892f84164_1graph.txt" -copyts -start_at_zero -f mp4 -ss 00:06:54.000 -c:v:0 hevc -hwaccel:v:0 cuda -hwaccel_device:v:0 0 -hwaccel_output_format:v:0 cuda -c:v:1 mjpeg -i "D:\电视剧\狂飙 (2023)\Season 1\狂飙 - S01E20 - 第 20 集.mp4" -filter_complex "[0:0]superscale_cuda@f1=w=720:h=404,setsar@f2=sar=sar[f2_out0]" -map [f2_out0] -map 0:1 -sn -c:v:0 h264_nvenc -b:v:0 3810171 -g:v:0 75 -maxrate:v:0 3810171 -bufsize:v:0 7620342 -keyint_min:v:0 75 -r:v:0 25 -profile:v:0 main -c:a:0 copy -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "D:\programs\embyserver-win-x64-3.5.3.0\programdata\transcoding-temp\1483D6\1483D6.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 138 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "D:\programs\embyserver-win-x64-3.5.3.0\programdata\transcoding-temp\1483D6\1483D6_%d.ts" 2023-02-16 12:22:53.305 Info App: AppendExtraLogData - Read graph file: D:\programs\embyserver-win-x64-3.5.3.0\programdata\logs\ffmpeg-transcode-51cd2929-52da-45f0-a0ed-b40892f84164_1graph.txt 2023-02-16 12:22:53.305 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 1,251.00 bytes Graph Count: 1 2023-02-16 12:22:53.305 Info App: AppendExtraLogData - File Deleted 2023-02-16 12:22:53.305 Info App: ProcessRun 'StreamTranscode 51cd29' Process exited with code 1 - Failed and the ffmpeg-transcode log is in attachment. Error is: Impossible to convert between the formats supported by the filter 'setsar@f2' and the filter 'auto_scale_0' Please tell me what's the wrong. Thank you! Quote emby version: 4.7.11 ffmpeg-transcode-51cd2929-52da-45f0-a0ed-b40892f84164_1.txt Edited February 17, 2023 by Happy2Play edited visible urls/ips
Happy2Play 9800 Posted February 17, 2023 Posted February 17, 2023 Looks to be something in the HWA code, does it play with HWA disabled? Increasing your Global Remote Bitrate Limit: 4,000,000 bps slightly would/should allow it to Direct Play. Item "Bitrate":4101049
hotwill 3 Posted February 17, 2023 Author Posted February 17, 2023 Yes, disabled HWA or Direct Play works fine. The error occurs when hardware transcoding is enabled. 1
Happy2Play 9800 Posted February 17, 2023 Posted February 17, 2023 Per your other topic You mentioned it happens on iOS also, can you port that log. No need for multiple topics.
hotwill 3 Posted February 17, 2023 Author Posted February 17, 2023 That topic wrote in the wrong place, ignore it. When playing using an iOS client, the same error occurs. Attachment is de ffmpeg log. ffmpeg-transcode-dc91a39b-e929-4c2d-be4e-973c6b481b56_1.txt
Luke 42185 Posted February 17, 2023 Posted February 17, 2023 @softworkz is looking into this, thanks.
Happy2Play 9800 Posted February 17, 2023 Posted February 17, 2023 Looks similar to the NVDEC vs CUVID issues but this card does not appear to have a CUVID option.
softworkz 5125 Posted March 3, 2023 Posted March 3, 2023 @hotwill - Can you please install the latest Nvidia drivers, restart the computer and retry? Then, please post the hardware detection log. Thanks
hotwill 3 Posted March 3, 2023 Author Posted March 3, 2023 The Nvidia drivers is already lastest. @softworkz
Luke 42185 Posted March 5, 2023 Posted March 5, 2023 On 3/3/2023 at 9:33 AM, hotwill said: The Nvidia drivers is already lastest. @softworkz What driver version number is installed?
softworkz 5125 Posted March 6, 2023 Posted March 6, 2023 On 3/3/2023 at 8:51 AM, softworkz said: please post the hardware detection log. Something must be very wrong on your system when you're not seeing any CUVID options.
hotwill 3 Posted March 6, 2023 Author Posted March 6, 2023 5 hours ago, softworkz said: Something must be very wrong on your system when you're not seeing any CUVID options. @Luke @softworkz Here is the detection log. hardware_detection-63813705236.txt 1
visproduction 328 Posted March 12, 2023 Posted March 12, 2023 Similar issue with Linux server. Apparently nvidia support for CUVID has some holes. This post is from 2020, but maybe is useful. https://github.com/NVIDIA/cuda-samples/issues/46
softworkz 5125 Posted March 12, 2023 Posted March 12, 2023 On 3/6/2023 at 6:22 AM, hotwill said: @Luke @softworkz Here is the detection log. Thanks. The detection log _does_ show the cuvid decoders. Can you please go to the dashboard "Transcoding" page and set HW acceleration to "Advanced" and see whether the CUVID decoders are listed there?
hotwill 3 Posted March 13, 2023 Author Posted March 13, 2023 11 hours ago, softworkz said: Thanks. The detection log _does_ show the cuvid decoders. Can you please go to the dashboard "Transcoding" page and set HW acceleration to "Advanced" and see whether the CUVID decoders are listed there? What's the meaning of "The detection log _does_ show the cuvid decoders"? @softworkz Here is the "Advanced" page:
softworkz 5125 Posted March 13, 2023 Posted March 13, 2023 4 minutes ago, hotwill said: What's the meaning of "The detection log _does_ show the cuvid decoders" They weren't visible in the hw decoders list in the log: Can you try with the HEVC CUVID decoder? (check box and move to top)
hotwill 3 Posted March 14, 2023 Author Posted March 14, 2023 On 3/13/2023 at 3:31 PM, softworkz said: They weren't visible in the hw decoders list in the log: Can you try with the HEVC CUVID decoder? (check box and move to top) HEVC CUVID decoder works fine. Why CUVID works fine but NVDEC does not?
softworkz 5125 Posted March 14, 2023 Posted March 14, 2023 43 minutes ago, hotwill said: HEVC CUVID decoder works fine. Why CUVID works fine but NVDEC does not? We haven't been able to identify a clear pattern. In most cases, both are working, but sometimes only one of them. That's why we're even having both as option. Sorry for the inconvenience.
Happy2Play 9800 Posted March 14, 2023 Posted March 14, 2023 9 hours ago, hotwill said: HEVC CUVID decoder works fine. Why CUVID works fine but NVDEC does not? Several existing topics, suggest fixed in next beta.
RedWings 15 Posted March 15, 2023 Posted March 15, 2023 (edited) Hello, I think i have the same error with a RTX 3060 12Go, i have juste disableb it for transcoding for now. Edited March 15, 2023 by RedWings
Luke 42185 Posted May 14, 2023 Posted May 14, 2023 This is resolved in the upcoming 4.8 server release. Thanks.
