Super957 24 Posted February 16, 2023 Posted February 16, 2023 I have strange problem with my smartphone (android) with mobile data and also with computer in office to conncet to my server. If in my smartphone i use app emby not problem, but if i try to conncet trough web browser with: http://xxxxxxxxxxx.homepc.it port: 8096 a web page of emby appear with: Select server - add server or emby conncet i try add server an error connection appear, why this ? Thank Hispa
GrimReaper 4851 Posted February 16, 2023 Posted February 16, 2023 12 minutes ago, Super957 said: but if i try to conncet trough web browser with: http://xxxxxxxxxxx.homepc.it port: 8096 a web page of emby appear with: Select server - add server or emby conncet If you were using that address you wouldn't have that page presented; you're using hosted Web app (app.emby.media) but since your screenshot is cut off, can't see whether over http or https?
Super957 24 Posted February 16, 2023 Author Posted February 16, 2023 53 minutes ago, GrimReaper said: Se stessi usando quell'indirizzo non avresti quella pagina presentata; stai usando un'app Web ospitata (app.emby.media) ma poiché lo screenshot è stato tagliato, non riesci a vedere se su HTTP o HTTPS? Yes is true.... connecting trough web and not app.emby.media i connect Thank Hispa
Luke 42186 Posted February 20, 2023 Posted February 20, 2023 If you haven't setup ssl on your emby server then you need to use http://app.emby.media
