echoxxzz 22 Posted February 16, 2023 Posted February 16, 2023 All my music is in Flac format and much of it is Hi-Res (90-192Hz/24-bit). My phone is setup to transcode down to 128kpbs AAC if I'm connecting over the Internet to save on my mobile data plan. I noticed that Android Auto doesn't honor the setting on my phone and continues to stream everything directly. Is there a way to change this and if not could it be a future option?
Luke 42243 Posted February 21, 2023 Posted February 21, 2023 HI, what version of Emby for Android are you running?
echoxxzz 22 Posted February 21, 2023 Author Posted February 21, 2023 (edited) Currently 3.2.92 but I can try some older versions if you think it worked at one time. Edited February 21, 2023 by echoxxzz
echoxxzz 22 Posted March 27, 2023 Author Posted March 27, 2023 Internet Quality = 128kbps. The phone works and it streams music at 128kbps but when I connect it to the cars Android Auto it direct plays.
Luke 42243 Posted March 27, 2023 Posted March 27, 2023 Did you try setting the music Internet quality setting?
echoxxzz 22 Posted March 27, 2023 Author Posted March 27, 2023 That is the setting that I set to 128kbps. It works fine if the phone isn't connected to the car.
