zhibo 0 Posted February 16, 2023 Posted February 16, 2023 embyserver.txt Hi, I have this playback error and then I purchased the Emby Premiere Key but still got this error. And below is the log, please take a look.
Luke 42242 Posted February 16, 2023 Posted February 16, 2023 Hi, is this with a bluray folder structure? Are you able to play normal video files?
Happy2Play 9811 Posted February 16, 2023 Posted February 16, 2023 What was played? Was there a ffmpeg log for that playback? It there a reason you are on 4.7.8.0 and not current release 4.7.11.0?
zhibo 0 Posted February 16, 2023 Author Posted February 16, 2023 6 minutes ago, Luke said: Hi, is this with a bluray folder structure? Are you able to play normal video files? Hi, I noticed I cannot play some blueray video, but I can play this one in same folder.
zhibo 0 Posted February 16, 2023 Author Posted February 16, 2023 5 minutes ago, Happy2Play said: What was played? Was there a ffmpeg log for that playback? It there a reason you are on 4.7.8.0 and not current release 4.7.11.0? This is the movie was played. And no other log for this. No, I can upgrade and try again.
Luke 42242 Posted February 16, 2023 Posted February 16, 2023 Do you have any plain video files to test for comparison purposes?
zhibo 0 Posted February 16, 2023 Author Posted February 16, 2023 9 minutes ago, Luke said: Do you have any plain video files to test for comparison purposes? do you mean I should make a blueray folder to test? How to make a blueray folder btw?
Happy2Play 9811 Posted February 16, 2023 Posted February 16, 2023 1 minute ago, zhibo said: do you mean I should make a blueray folder to test? How to make a blueray folder btw? No he means do you have any issues playing mkv/mp4 files? Do the items that don't play actually show Media Info in Emby?
zhibo 0 Posted February 16, 2023 Author Posted February 16, 2023 10 minutes ago, Happy2Play said: No he means do you have any issues playing mkv/mp4 files? Do the items that don't play actually show Media Info in Emby? These videos don't play also cannot show Media Info. MKV and mp4 works and some blueray works as well.
Happy2Play 9811 Posted February 16, 2023 Posted February 16, 2023 7 minutes ago, zhibo said: These videos don't play also cannot show Media Info. MKV and mp4 works and some blueray works as well. If there is no media info they will fail as server does not know how to play them. You can try to refresh metadata on a movie to see if it populates but per the server log ffprobe appears to have issue at least on that item. No idea what item it actually is though. 2023-02-15 17:30:47.591 Error App: Error in ffprobe *** Error Report *** Version: 4.7.8.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42962 SMP Tue Jan 31 23:18:09 CST 2023 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Exception: System.Exception: Clip info file 00109.clpi has an unknown file type HDMV0300. at BDInfo.BDROM.Scan() at BDInfo.BdInfoExaminer.GetDiscInfo(String path) at BlurayMounter.BlurayMounter.Mount(ReadOnlyMemory`1 mediaPath, ReadOnlyMemory`1 container, CancellationToken cancellationToken) at Emby.Server.Implementations.IO.MediaMountManager.Mount(ReadOnlyMemory`1 mediaPath, ReadOnlyMemory`1 container, CancellationToken cancellationToken) at Emby.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](MetadataResult`1 metadataResult, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, MetadataResult`1 itemResult, String logName, MetadataRefreshOptions options, LibraryOptions libraryOptions, RefreshResult refreshResult, CancellationToken cancellationToken) Source: BlurayMounter TargetSite: Void Scan()
Happy2Play 9811 Posted February 16, 2023 Posted February 16, 2023 (edited) @Lukewas this ever improved? As it looks like the same/similar issue "HDMV0300". Edited February 16, 2023 by Happy2Play
Luke 42242 Posted February 16, 2023 Posted February 16, 2023 No, there's still work to do there, but for the best experience possible, I would suggest converting to mkv using MakeMKV.
zhibo 0 Posted February 16, 2023 Author Posted February 16, 2023 2 hours ago, Happy2Play said: If there is no media info they will fail as server does not know how to play them. You can try to refresh metadata on a movie to see if it populates but per the server log ffprobe appears to have issue at least on that item. No idea what item it actually is though. 2023-02-15 17:30:47.591 Error App: Error in ffprobe *** Error Report *** Version: 4.7.8.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk Operating system: Linux version 4.4.180+ (root@build2) (gcc version 8.5.0 (GCC) ) #42962 SMP Tue Jan 31 23:18:09 CST 2023 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.Exception: System.Exception: Clip info file 00109.clpi has an unknown file type HDMV0300. at BDInfo.BDROM.Scan() at BDInfo.BdInfoExaminer.GetDiscInfo(String path) at BlurayMounter.BlurayMounter.Mount(ReadOnlyMemory`1 mediaPath, ReadOnlyMemory`1 container, CancellationToken cancellationToken) at Emby.Server.Implementations.IO.MediaMountManager.Mount(ReadOnlyMemory`1 mediaPath, ReadOnlyMemory`1 container, CancellationToken cancellationToken) at Emby.Providers.MediaInfo.FFProbeVideoInfo.ProbeVideo[T](MetadataResult`1 metadataResult, MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.RunCustomProvider(ICustomMetadataProvider`1 provider, MetadataResult`1 itemResult, String logName, MetadataRefreshOptions options, LibraryOptions libraryOptions, RefreshResult refreshResult, CancellationToken cancellationToken) Source: BlurayMounter TargetSite: Void Scan() I try to refresh metadata, but media info still not showed. What can I try next step?
seanbuff 1356 Posted February 16, 2023 Posted February 16, 2023 24 minutes ago, zhibo said: What can I try next step? 1 hour ago, Luke said: I would suggest converting to mkv using MakeMKV
zhibo 0 Posted February 16, 2023 Author Posted February 16, 2023 They are in multi files like this. I don't think it will work.
seanbuff 1356 Posted February 16, 2023 Posted February 16, 2023 19 minutes ago, zhibo said: They are in multi files like this. I don't think it will work. Just load the 'index.bdmv' file in MakeMKV and save as an .mkv file
zhibo 0 Posted February 17, 2023 Author Posted February 17, 2023 19 hours ago, seanbuff said: Just load the 'index.bdmv' file in MakeMKV and save as an .mkv file but it doesn't make sense for me, I have more than 100 movies and each 50g, all these movies can be played in infuse. I want to watch remotely so I purchased the membership, but now most of them cannot be played in emby. I cannot convert all movies.
Happy2Play 9811 Posted February 17, 2023 Posted February 17, 2023 If I understand correctly the plugin has to updated to support this change in HDMV0300 discs. As currently they are not supported per the linked topic. 1
zhibo 0 Posted February 17, 2023 Author Posted February 17, 2023 1 hour ago, Happy2Play said: If I understand correctly the plugin has to updated to support this change in HDMV0300 discs. As currently they are not supported per the linked topic. which plugin should I update?
Happy2Play 9811 Posted February 17, 2023 Posted February 17, 2023 Just now, zhibo said: which plugin should I update? You can't as Emby "Bluray Folder Support" plugin (BlurayMounter.dll) need updated per the linked topic.
