sameh1925 24 Posted February 16, 2023 Posted February 16, 2023 I have a m3u file like this And I add the channel to be played by adding IPTV But the problem is that the channel only works well on one device, and when you run any other device on the same channel, the broadcast stops at the other device
Luke 42242 Posted February 16, 2023 Posted February 16, 2023 Hi, sounds like your provider only allows one stream at a time. If you import this into live tv using an m3u tuner, the server can sometimes share it across devices. 1
sameh1925 24 Posted February 16, 2023 Author Posted February 16, 2023 Thanks for the quick reply and a thorough answer But to try this emby premiere subscription is required May I try emby premiere one day to try this
Luke 42242 Posted February 16, 2023 Posted February 16, 2023 We work very hard on emby and we thank you for your support.
