benlad 1 Posted February 15, 2023 Posted February 15, 2023 (edited) I have just set up live TV using an HD Homerun device. The TV guide on the emby app on my Amazon Fire TV is blank. I set the default tab to Guide and now when I go to live TV it is still blank, but it also hangs and all I can do is exit. The guide works fine in the web app an on the emby app via my android phone. Emby Server: 4.7.11.0 Emby Fire TV: 2.0.79a Edited February 15, 2023 by benlad Added version app numbers
Luke 42245 Posted February 15, 2023 Posted February 15, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
benlad 1 Posted February 15, 2023 Author Posted February 15, 2023 Yeah, that works. It looks like it has moved on quite a bit from the fire TV app. Do you not keep them with similar features/codebase?
ebr 16337 Posted February 16, 2023 Posted February 16, 2023 Hi. We're working on unifying to the app you side-loaded. Thanks.
