jluce50 122 Posted March 1, 2023 Author Posted March 1, 2023 I believe it was 'cache=yes' and 'cache-secs=30'
Guest Posted March 1, 2023 Posted March 1, 2023 Did you test using a greater duration? You could also try this: https://mpv.io/manual/master/#options-demuxer-readahead-secs
Guest Posted March 2, 2023 Posted March 2, 2023 (edited) Also, try updating the driver for onboard audio. Especially if it has an optical output Often this is Realtek Edited March 2, 2023 by generiq
jluce50 122 Posted March 6, 2023 Author Posted March 6, 2023 On 3/2/2023 at 2:47 PM, Luke said: Hi, has this helped? It helped, but didn't eliminate the dropouts entirely. It went from every few seconds at its worst, to every few minutes. It's still enough to take you out of whatever you're watching when it happens.
