damien_c2 7 Posted February 13, 2023 Posted February 13, 2023 (edited) Hello, it me again i have found an other transcoding issue. When transcoding is enable and bitrate is reduced. after 10 secs to 5 min the video stop (i think emby stop sending buffer for some reason). And it happen only when the bitrate (audio or video or both) is reduced. (if i set quality to max it dont happen) @Luke im not sure if the relate to the other transcode issue. Options: AudioPlaybackTranscoding Enable VideoPlaybackTranscoding Not enable PlaybackRemuxing Enable embyserver.txt ffmpeg-remux-573d944e-35b1-4a2b-954e-a06083093ffc_1.txt Edited February 13, 2023 by damien_c2
Happy2Play 9800 Posted February 13, 2023 Posted February 13, 2023 Do you see the same results in a different browser?
damien_c2 7 Posted February 14, 2023 Author Posted February 14, 2023 1 hour ago, Happy2Play said: Do you see the same results in a different browser? i have try whit edge and yes.
damien_c2 7 Posted February 15, 2023 Author Posted February 15, 2023 2 hours ago, Luke said: I think this might be your issue. Hello it working, but only when the bitrare is reduce it stop working. If it cause the issue why in auto still try to reduce bitrate ?
Happy2Play 9800 Posted February 15, 2023 Posted February 15, 2023 Auto is always conservative on Remote connections and can default to fallback transcoding values. Personally, I have all users set clients to max and control internet stream rate per user or globally on the server. 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectStream limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectStream limit: media bitrate: 11708872, max bitrate: 4000000
damien_c2 7 Posted February 16, 2023 Author Posted February 16, 2023 4 hours ago, Happy2Play said: Auto is always conservative on Remote connections and can default to fallback transcoding values. Personally, I have all users set clients to max and control internet stream rate per user or globally on the server. 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectStream limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectStream limit: media bitrate: 11708872, max bitrate: 4000000 It possible to set the quality value globaly how ?
Happy2Play 9800 Posted February 16, 2023 Posted February 16, 2023 3 minutes ago, damien_c2 said: It possible to set the quality value globaly how ? No as quality is a client dependent setting normally set to Auto. You can only control a max "Internet streaming bitrate limit (Mbps)" in Network or per user settings.
damien_c2 7 Posted February 16, 2023 Author Posted February 16, 2023 7 hours ago, Happy2Play said: Auto is always conservative on Remote connections and can default to fallback transcoding values. Personally, I have all users set clients to max and control internet stream rate per user or globally on the server. 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectStream limit: media bitrate: 11708872, max bitrate: 4000000 2023-02-13 13:54:59.458 Info App: Bitrate exceeds DirectStream limit: media bitrate: 11708872, max bitrate: 4000000 But instead of stop sending data, it should still send no ?
