Darren & Gemma 12 Posted February 11, 2023 Posted February 11, 2023 Hi I had an issue where the TV Guide wasn't showing 98% of the channel logos, so I completed removed Live TV and reset it up. Its improved, but still missing channel logos and data beyond channel 28. Set up is: Emby Server on QNAP - v.4.7.11.0 Live TV - HDHomeRun Connect Duo Emby Data Guide (GBR-1000118-DEFAULT) Line Up: United Kingdom (National) See below Guide: Every channel is missing except for: Any ideas or suggestions please? @Luke? Thanks
Luke 42237 Posted February 12, 2023 Posted February 12, 2023 Hi, did you check the Channel management screen in Emby Live Tv setup to ensure that your HDHR channels are mapped to guide channels?
Darren & Gemma 12 Posted February 12, 2023 Author Posted February 12, 2023 Hi @Luke I hadn't, but the guide data channels do not seem to go any further than 28?? Attached.
Darren & Gemma 12 Posted February 12, 2023 Author Posted February 12, 2023 I think I've sorted it, thanks @Luke
Luke 42237 Posted February 12, 2023 Posted February 12, 2023 1 hour ago, Darren & Gemma said: I think I've sorted it, thanks @Luke Hi, what was the solution?
