josevh 9 Posted February 11, 2023 Posted February 11, 2023 (edited) On Android, via the app and mobile web browser, where is the date picker? The latest server release notes indicate that it should be to the left of the guide settings button at top (confirmed in desktop view) but it is not visible for mobile. Edited February 11, 2023 by josevh
GrimReaper 4896 Posted February 11, 2023 Posted February 11, 2023 As replied il to your query in the other topic: 12 minutes ago, josevh said: The Live TV guide has no date picker on mobile browser and the Android application.
josevh 9 Posted February 11, 2023 Author Posted February 11, 2023 Hi, there's no date options in the sort menu popup.
GrimReaper 4896 Posted February 11, 2023 Posted February 11, 2023 You are right, could've sworn it was there.
MBSki 1115 Posted February 11, 2023 Posted February 11, 2023 1 hour ago, josevh said: On Android, via the app and mobile web browser, where is the date picker? The latest server release notes indicate that it should be to the left of the guide settings button at top (confirmed in desktop view) but it is not visible for mobile. I just noticed that it shows up if you turn it to a horizontal view. It's not available in vertical view though. 1
josevh 9 Posted February 11, 2023 Author Posted February 11, 2023 2 minutes ago, MBSki said: I just noticed that it shows up if you turn it to a horizontal view. It's not available in vertical view though. Good catch! Yes! A temporary workaround.
MBSki 1115 Posted February 11, 2023 Posted February 11, 2023 1 minute ago, josevh said: Good catch! Yes! A temporary workaround. Yea, not the greatest, but it'll do for now. I guess space is a little limited.
Luke 42242 Posted February 12, 2023 Posted February 12, 2023 9 hours ago, MBSki said: Yea, not the greatest, but it'll do for now. I guess space is a little limited. Correct. Putting it above the guide like we were means you lose 1-1.5 visible guide rows.
Carlo 4561 Posted February 14, 2023 Posted February 14, 2023 @Luke Date selection is missing in vertical view. The look and feel of the mobiles is good but functionality should match. In the wide view you see both the date and the icon but in vertical mode you only get the icon. Thus, when only the icon is available (vertical) above the stations, we should have the date selector as the first option on the resulting settings dialog.
