Flest 8 Posted February 11, 2023 Posted February 11, 2023 (edited) if the device supports hdr, why does the server use tone mapping? source - 4k hdr android can play h265 with hdr but the server uses h264 for transcoding... is this a bug? server should use h264 with tone mapping for devices without h265 support I'm right? Edited February 11, 2023 by Flest
GrimReaper 4851 Posted February 11, 2023 Posted February 11, 2023 Have you explored Stats for Nerds to see reason for transcoding? You can observe same in server Dashboard. And you can also post ffmpeg log created, as transcoding reasons can be various.
ebr 16307 Posted February 11, 2023 Posted February 11, 2023 Hi. Transcoding to HDR is not currently possible. We can investigate why your item is transcoding with the information requested above. Thanks. how to report a media playback issue.
Flest 8 Posted February 11, 2023 Author Posted February 11, 2023 1 hour ago, ebr said: Hi. Transcoding to HDR is not currently possible. but why? doesn't nvenc support hdr encoding? 1 hour ago, ebr said: We can investigate why your item is transcoding with the information requested above. Thanks. because I chose transcoding) for local playback i use direct playback or kodi, but when i'm not at home i use transcoding. and i would like to be able to transcode to h265 (almost all devices support h265) why does it encode in h264 if the device supports h265?
GrimReaper 4851 Posted February 11, 2023 Posted February 11, 2023 1 minute ago, Flest said: and i would like to be able to transcode to h265 (almost all devices support h265) There is no transcoding to H.265 in Emby, only conversions can be done using it. You can lend your support here:
Flest 8 Posted February 11, 2023 Author Posted February 11, 2023 5 minutes ago, GrimReaper said: There is no transcoding to H.265 in Emby, only conversions can be done using it. You can lend your support here: I can't open this picture, link opens the topic
GrimReaper 4851 Posted February 11, 2023 Posted February 11, 2023 It IS a link to a Feature Request topic with the title "Transcode in H265".
Flest 8 Posted February 11, 2023 Author Posted February 11, 2023 (edited) 8 minutes ago, GrimReaper said: It IS a link to a Feature Request topic with the title "Transcode in H265". I don't see an answer in this topic, off topic seems like the requests is dead ((( first post from 2017 Edited February 11, 2023 by Flest
GrimReaper 4851 Posted February 11, 2023 Posted February 11, 2023 7 minutes ago, GrimReaper said: It IS a link to a Feature Request topic with the title "Transcode in H265". Meaning same has been requested and the topic is still open as it is not yet implemented, I don't know of any other way to explain it to you. You can support it by up voting first post.
Flest 8 Posted February 11, 2023 Author Posted February 11, 2023 5 minutes ago, GrimReaper said: Meaning same has been requested and the topic is still open as it is not yet implemented, I don't know of any other way to explain it to you. You can support it by up voting first post. I understand that the request is open But it's been 5.5 years... something tells me that voting will not change the situation ((( it is unlikely that they will ever do this, it is more likely that n265 will become obsolete sooner at such a speed of implementation, it is necessary to start implementing av1
GrimReaper 4851 Posted February 11, 2023 Posted February 11, 2023 2 minutes ago, Flest said: at such a speed of implementation, it is necessary to start implementing av1 You can support that one as well:
Luke 42186 Posted February 12, 2023 Posted February 12, 2023 Actually it's not related to either of those. When transcoding, the HDR info is lost, so it has to be tonemapped.
softworkz 5127 Posted February 12, 2023 Posted February 12, 2023 9 hours ago, Flest said: at such a speed of implementation, it is necessary to start implementing av1 Now tell me - assuming we would be able to transcode HEVC/HDR to AV1/HDR - how does the transcoded video get transferred to the client (streaming protocol) and which clients would be able to play this reliably?
Flest 8 Posted February 12, 2023 Author Posted February 12, 2023 5 hours ago, Luke said: Actually it's not related to either of those. When transcoding, the HDR info is lost, so it has to be tonemapped. no... nvidia nvenc doesn't support hdr encoding? cpu supports its my rip 4k hdr -> 1080 hdr
