IkeTaylor11 61 Posted February 10, 2023 Posted February 10, 2023 I have a few channels that don't have any EPG mapped to them, it doesn't exist. Is there anyway to do a permanent poster image for the channels in the "On Now" section in Emby? Right now it is taking the channel logo and using that. I would like to create my own custom images and use them. I have attached what I am referring to. I would like the images to be similar to the rest of the channels, for aesthetic purposes.
Luke 42242 Posted February 10, 2023 Posted February 10, 2023 Hi, did you try setting your own channel logos?
IkeTaylor11 61 Posted February 10, 2023 Author Posted February 10, 2023 8 hours ago, Luke said: Hi, did you try setting your own channel logos? Yes, that’s where those images are pulling from now. I used the standard 360x270 image size to it matches the rest of the channels in the guide. For the On Now section I would like an image to be the size of the program images. To match the other programs that do pull from EPG.
