bruor 43 Posted February 10, 2023 Posted February 10, 2023 (edited) Using Chromecast w/ Google TV, this is not a problem in the web app. I've noticed an issue with the EPG not working as expected when switching users. When changing to another user in the Android TV app, if I go directly to the guide, it'll take multiple minutes to load, and in the process will sometimes crash the app (it relaunches back to the user selection screen since I have it configured that way). However, if I play a channel first, then launch the guide it'll load almost instantly. This happens every time I switch users. The last user to access the guide successfully does not have this issue again even if I force stop the app and reopen it. Edited February 10, 2023 by bruor
Luke 42245 Posted February 10, 2023 Posted February 10, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
bruor 43 Posted February 10, 2023 Author Posted February 10, 2023 I can try that tomorrow, I can tell you that I have no issues with this use case on my Pixel 6 Pro. Since getting sideload to work likely requires ADB, would a logcat be helpful?
bruor 43 Posted February 10, 2023 Author Posted February 10, 2023 The issue does not exist in the standard Android app on the Chromecast
Luke 42245 Posted February 21, 2023 Posted February 21, 2023 On 2/10/2023 at 9:58 AM, bruor said: The issue does not exist in the standard Android app on the Chromecast Are you happy with continuing to use that?
bruor 43 Posted February 21, 2023 Author Posted February 21, 2023 In the long term will the android app become the TV app? I did notice that there are some differences between the 2, I will need to test the sideloaded app longer term and report back. One thing I won't like is the need to manually update the app. 1
pwhodges 2033 Posted February 21, 2023 Posted February 21, 2023 I believe the aim is for the general Android app to replace the Android TV app, when it has got close enough in features for people to accept it. Paul
