HawkXP71 112 Posted February 11, 2023 Author Posted February 11, 2023 5 hours ago, Luke said: every single season must be tagged with the season number in the emby metadata editor, and every single episode must be tagged with the episode number and season number in the metadata editor. Every season.nfo has the correct ID, and every episode has an id as well. Its still not showing up.. This is just frustrating. If I provide a location download a tarball/zip file of my directory, and my emby directory (just tell me what you want) so someone can debug this with a real debugging environment
Luke 42288 Posted February 12, 2023 Posted February 12, 2023 On 2/10/2023 at 9:37 PM, HawkXP71 said: Every season.nfo has the correct ID, and every episode has an id as well. That's good but in order to get to the bottom of this you'll need to check exactly what I mentioned.
Solution Luke 42288 Posted February 12, 2023 Solution Posted February 12, 2023 On 2/10/2023 at 3:52 PM, HawkXP71 said: Is this stored in the nfo files? Or do I have to do it by hand? It should be in sync with the nfo but I would check inside of emby to be sure.
HawkXP71 112 Posted February 12, 2023 Author Posted February 12, 2023 1 hour ago, Luke said: That's good but in order to get to the bottom of this you'll need to check exactly what I mentioned. And what does that mean? Check each media item and each season? Is that available in the API? Honestly, with 26 seaons and 350+ episodes.... thats a tall order to check via a UI
Luke 42288 Posted February 12, 2023 Posted February 12, 2023 Unfortunately for right now, yes. I'll have to add more logging to indicate the reason why it's getting skipped for a series.
HawkXP71 112 Posted February 12, 2023 Author Posted February 12, 2023 Just now, Luke said: Unfortunately for right now, yes. I'll have to add more logging to indicate the reason why it's getting skipped for a series. That would be great. Even if it was a debug level log message 1
HawkXP71 112 Posted February 12, 2023 Author Posted February 12, 2023 18 hours ago, Luke said: It should be in sync with the nfo but I would check inside of emby to be sure. FINALLY found it!! I had a copy of the Unaired Pilot. The short that they did in college. It was showing as a Season 0, but didnt have a tvdb id. I moved it into an Extras via creating a Season 0, and that solved the problem... I understand the reasoning, but this definitely could have used some form of debug messaging. 1
HawkXP71 112 Posted February 13, 2023 Author Posted February 13, 2023 Just now, Luke said: Where was it before? It was just at the root south park directory. 1
pr3dict 33 Posted February 15, 2023 Posted February 15, 2023 (edited) On 2/9/2023 at 6:27 PM, HawkXP71 said: Im not quite sure what you mean by provider settings. for the library the episode and series metadata downloaders are here You should remove this screenshot as it has your entire server address... Edited February 15, 2023 by pr3dict
HawkXP71 112 Posted February 15, 2023 Author Posted February 15, 2023 5 minutes ago, pr3dict said: You should remove this screenshot as it has your entire server address... Thanks.. if you could remove it from your quote as well
