Ronstang 294 Posted February 9, 2023 Posted February 9, 2023 Title says it all, came back to my computer late last night before I went to bed and no artwork, same this morning. I have refreshed and I tried restarting the server several times to no avail. embyserver.txt
ebr 16307 Posted February 9, 2023 Posted February 9, 2023 Hi. Is "T:" a mapped network drive? System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path 'T:\~~TCM HEVC Dupes #2\The Seventh Victim (1943) TCMFPAM\poster.jpg'.
Ronstang 294 Posted February 9, 2023 Author Posted February 9, 2023 (edited) No, it is in a USB rack connected directly to the server emby is on. And I just checked the drive and it is working fine. Edited February 9, 2023 by Ronstang
Happy2Play 9800 Posted February 10, 2023 Posted February 10, 2023 You do appear to have a database issue/corruption also. SQLitePCL.pretty.SQLiteException: Error: cannot rollback - no transaction is active SQLitePCL.pretty.SQLiteException: Corrupt: database disk image is malformed Corrupt Database : (emby.media) But you log is flooded with "Could not find a part of the path 'T:\~~TCM HEVC Dupes #2\*************" items.
Ronstang 294 Posted February 10, 2023 Author Posted February 10, 2023 (edited) Thanks guys....in a roundabout way you gave me a clue to the problem. I rearranged my duplicate movie store recently but forgot to update the paths in the proper library so that "T" drive directory no longer exists....which results in a failed guide refresh.....which means the ever changing "on now" could not update either. I fixed the paths, which immediately fixed the issue. CORRECTION....this fixed part of it but I don't have time to shut everything down and mess with the database at the moment. Considering all the problems I am having with Windows and emby I think it's simply time to replace the small SSD it all resides on. For a while it was my recording directory which filled up daily for a long time so this SSD is probably past it's prime considering its only 256G anyway. Edited February 10, 2023 by Ronstang 1
Ronstang 294 Posted February 10, 2023 Author Posted February 10, 2023 I just flushed the entire database and it is rebuilding now, albeit in a very stripped down version....but everything is working as it should again. I had way too many libraries, most of which were for testing purposes that I really no longer needed and some containing older H.264 versions of my movies that have either been replaced by newer H.265 versions or I will convert the ones I can't get so those libraries are not needed either. Anyway I am about to get my second server up and online for only ready for prime time content so it can be accessed by the family and then this server will become my testing and arranging server only on a new fresh install of Windows so I will rebuild it from scratch at that point on a new SSD. 1
