papugo1980 4 Posted February 8, 2023 Posted February 8, 2023 Salve a tutti , da poco tempo ho cambiato tv, Tcl serie c83 , ha Google tv, e ho difficoltà a riprodurre alcuni titoli con audio dolby,aac, dolby+ , in pratica sento l audio distorto e video a scatti, questo succede quando il bitrate dell audio ha 640kbps o più, nelle statische per nerd c’è scritto dolby diretto . ho provato a premere due volte “correggi riproduzione” facendo così l audio viene riprodotto normalmente senza distorsione o scatti, e in statistiche per nerd appare scritto dolby (software decode) ,impostando un player esterni va tutto liscio. Cosa posso fare per risolvere senza premere correggi riproduzione? Allego il log di ffmpeg relativo ad un file riprodotto emby.txt
ebr 16332 Posted February 9, 2023 Posted February 9, 2023 Hi. If you are just using the TV speakers, try setting the audio option to "Mix down to stereo".
papugo1980 4 Posted February 9, 2023 Author Posted February 9, 2023 (edited) 1 hour ago, ebr said: Hi. If you are just using the TV speakers, try setting the audio option to "Mix down to stereo". Yes, I also tested this and it works, but I lose in audio quality, this TV has an integrated ONKYO soundbar and Dolby Atmos. I don't understand why with emby I have this problem and with Jellyfin for example not. I bought a premiere subscription because I prefer to use emby and I also like it on ios and on another lg tv, is it possible that this tcl can't solve the problem? Thank you Edited February 9, 2023 by papugo1980
ebr 16332 Posted February 9, 2023 Posted February 9, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
papugo1980 4 Posted February 9, 2023 Author Posted February 9, 2023 40 minutes ago, ebr said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. I've already tried this app, but the problem persists. If it can be useful, using for example bluetooth headphones, the problem does not arise, even when I use the integrated chromecast everything runs smoothly.
ebr 16332 Posted February 9, 2023 Posted February 9, 2023 Hi. Yes, if bluetooth headphones are connected, the app will automatically downmix to stereo. 1
