riverboat2001 20 Posted February 8, 2023 Posted February 8, 2023 I've noticed that the guide data is not working for some Channels, and not updating updating on some channels, and not deleting some channels. The error on screen is "Refresh Guide failed on Skynet" (I've tried different providers, but no change. I have attached the log As a separate issue (maybe linked) Trakt is no longer syncing, although i think this has been going on sometime embyserver.txt
Luke 42287 Posted February 8, 2023 Posted February 8, 2023 Hi, please take a look at this and it should help get you squared away: https://support.emby.media/support/solutions/articles/44002210894-corrupt-database
riverboat2001 20 Posted February 8, 2023 Author Posted February 8, 2023 Hi Luke, I'm trying to follow those instructions, and I've found the two files that I need to delete. But as soon as I exit out of emby (as per instructions) the files disappear. Restarting Emby causes them to come back, but I can't delete them as they are in use. Sorry to bug you, but how on earth do i delete these files please?
Happy2Play 9814 Posted February 8, 2023 Posted February 8, 2023 16 minutes ago, riverboat2001 said: Hi Luke, I'm trying to follow those instructions, and I've found the two files that I need to delete. But as soon as I exit out of emby (as per instructions) the files disappear. Restarting Emby causes them to come back, but I can't delete them as they are in use. Sorry to bug you, but how on earth do i delete these files please? Sorry but you have a corrupt database. SQLitePCL.pretty.SQLiteException: Corrupt: database disk image is malformed Unfortunately the database lock section will not apply. You can try to recover process but most likely will have to start a new database. Note all userdata is in that database so if you do not use the Server Configuration Backup plugin you may have to try and import the userdatas table from old to new assuming that table is not corrupted also.
riverboat2001 20 Posted February 9, 2023 Author Posted February 9, 2023 (edited) 2 hours ago, Happy2Play said: Sorry but you have a corrupt database. SQLitePCL.pretty.SQLiteException: Corrupt: database disk image is malformed Unfortunately the database lock section will not apply. You can try to recover process but most likely will have to start a new database. Note all userdata is in that database so if you do not use the Server Configuration Backup plugin you may have to try and import the userdatas table from old to new assuming that table is not corrupted also. When you say all userdata is in that database. Will I lose the users themselves, or the played states of shows? Will that affect all of the linked Rokus? Also the locations of my database doesn't match the images in the article that Luke linked to.: C:\Users\metsh\AppData\Roaming\Emby-Server\programdata We need the location of the library database files. They are located in the "data" directory under the first path shown. "/var/lib/emby" followed by "/data". "/var/lib/emby/data" is the location to use for each of the solutions below. I don't have any of those folders I DO have the server configuration back-up. Is it a matter of loading each one and seeing if it works? Is there a guide of what to do with those backups? As I can't see a way to "load" them. I'm guessing I grab what's there and paste them somewhere. Many Thanks for your time. Edited February 9, 2023 by riverboat2001
Happy2Play 9814 Posted February 9, 2023 Posted February 9, 2023 1 minute ago, riverboat2001 said: When you say all userdata is in that database. Will I lose the users themselves, or the played states of shows? Will that affect all of the linked Rokus? Also the locations of my database doesn't match the images in the article that Luke linked to.: C:\Users\metsh\AppData\Roaming\Emby-Server\programdata We need the location of the library database files. They are located in the "data" directory under the first path shown. "/var/lib/emby" followed by "/data". "/var/lib/emby/data" is the location to use for each of the solutions below. I don't have any of those folders Will not affect users but will affect playstate/resume/favorites (userdata). No affect on devices. Location will be platform prevalent, per the image it tell your general location on your system. C:\Users\metsh\AppData\Roaming\Emby-Server\programdata\data
riverboat2001 20 Posted February 9, 2023 Author Posted February 9, 2023 3 minutes ago, Happy2Play said: Will not affect users but will affect playstate/resume/favorites (userdata). No affect on devices. Location will be platform prevalent, per the image it tell your general location on your system. C:\Users\metsh\AppData\Roaming\Emby-Server\programdata\data It's late here, and I'm off on holiday tomorrow. I'll have an hour or so tomorrow am. How do I use those backups please? I've no idea how long this issue has been going on, so the backups may also have this issue in them! Many Thanks
Solution Happy2Play 9814 Posted February 9, 2023 Solution Posted February 9, 2023 6 minutes ago, riverboat2001 said: It's late here, and I'm off on holiday tomorrow. I'll have an hour or so tomorrow am. How do I use those backups please? I've no idea how long this issue has been going on, so the backups may also have this issue in them! Many Thanks Normally userdata is not affected that I know of so it should be a matter of shutting down Emby rename/delete the library.db, start Emby and do a library scan. Once finished go to the Server Configuration backup plugin and restore only userdata (since you do have the plugin installed). 1
riverboat2001 20 Posted February 9, 2023 Author Posted February 9, 2023 You GUY'S Absolute Heroes. Happy2Play: server configuration backup screen - Lifesaver Cheers l 1
