jan84 1 Posted February 7, 2023 Posted February 7, 2023 As title says. Install from play store. Log in. Exit. Try to load app it will get stuck on loading unless I clear data. Sideloaded app from website works but doesn't have my purchase so I can't play media.
Solution ebr 16337 Posted February 7, 2023 Solution Posted February 7, 2023 Hi. Make sure the addresses shown on the server dashboard are correct.
jan84 1 Posted February 7, 2023 Author Posted February 7, 2023 Manually removed the server and added it by ip. This fixed it. 1
