tm0323 3 Posted February 6, 2023 Posted February 6, 2023 Hey everyone, I was hoping to update to the latest server version. The package center says 4.7.8.0 says it's still the latest version but I can download 4.7.11.0 from the website. However, when I try to install it, it fails. I'm running DSM 7.1.1 on a DS215j. I believe I'm grabbing the correct file, it's name is "emby-server-synology7_4.7.11.0_armv7.spk". Whenever I check the admin dashboard it is detecting a new version, but for whatever reason the Synology package center isn't, or allowing me to install a new one.
Luke 42242 Posted February 6, 2023 Posted February 6, 2023 Hi, the package center version is just a little behind. You can install the latest version manually by downloading the spk from our website, or wait for the package center version to be updated.
tm0323 3 Posted February 6, 2023 Author Posted February 6, 2023 Ok, the manual install doesn’t appear to work for me. As long as the package center will eventually update I’ll be fine with that. Thanks for the reply, @Luke 1
pbohny 0 Posted February 20, 2023 Posted February 20, 2023 Same problem here: emby-server-synology7_4.7.11.0_armv7.spk is not accepted while manually installing on DS215j Any help or recommentdations?
Luke 42242 Posted February 21, 2023 Posted February 21, 2023 On 2/20/2023 at 7:49 AM, pbohny said: Same problem here: emby-server-synology7_4.7.11.0_armv7.spk is not accepted while manually installing on DS215j Any help or recommentdations? Hi, what exactly happens when you try?
tm0323 3 Posted April 14, 2023 Author Posted April 14, 2023 (edited) @LukeI just tried again today, still having the same problem. Here are the steps I took: Log into Synology NAS Stopped Emby service Selected Manual Install button Uploaded "emby-server-synology7_4.7.11.0_armv7.spk" file I still receive the error in the screenshot on my first post. Says "This package is not supported on the platform of DiskStation or is incompatible with the current DSM version". My current DSM version is DSM 7.1.1-42962 Update 4 and it says I'm up to date. Any thoughts on why this might be happening? I assume I'm grabbing the correct file to update. Edited April 14, 2023 by tm0323
RonV42 2 Posted April 15, 2023 Posted April 15, 2023 On 2/6/2023 at 2:35 PM, Luke said: Hi, the package center version is just a little behind. You can install the latest version manually by downloading the spk from our website, or wait for the package center version to be updated. Seems to be a lot behind still showing this on my DS1019+.
Luke 42242 Posted April 15, 2023 Posted April 15, 2023 6 hours ago, RonV42 said: Seems to be a lot behind still showing this on my DS1019+. HI, if package center is behind you can always install the latest version manually from our website: https://emby.media/download 1
Solution alucryd 318 Posted April 17, 2023 Solution Posted April 17, 2023 Please try the mono package (the one for all other armv7 devices on our website). The devices list is outdated, we will reflect that asap. 1
